P
Pete69zx
Andy Mac this is possibly another one for you...
What is the max mounting depth for the front speakers in an A3 8L?
I ideally want, the greatest RMS speaker i can find, allthough quality is the deciding factor here (as im sure it is with anyone that enjoys good clear precise music).
As an example i have found these possibilties...
Magnat Xcess 102
Principle - 2 way coax system
Power Handling RMS/max. - 60 / 110 Watts
Impedance - 4 Ohms
Frequency response - 42 - 32000 Hz
Crossover Frequencies - 3800 Hz
Sound pressure level - 90 dB
DIN-Diameter - 100 mm
Outer diameter - 139 mm with grille
Cutting out - 94 mm
Mounting depth - 48 mm
Infinity Kappa 42.7i
Diameter: 4" (10cm)
Power Handling, RMS: 50 watts
Power Handling, Peak: 150 watts
Sensitivity (2.83V/1m): 93dB
Frequency Response: 75Hz 25kHz
Nominal Impedance: 2 Ohms
Mounting Depth: 46mm
Cut-Out Diameter: 88mm
Thoughts & suggestions please.
Cheers.
Magnat Xcess 102
Impedance - 4 Ohms
Cutting out - 94 mm
Diameter: 4" (10cm)
Cheers.
