Volks AutosJMB Retrofits
Results 1 to 7 of 7
    Jul 2006
    160
    Sat Nav+ max SD Card Size?
    Hi All,
    Getting my car in a couple of weeks, need get some sd cards for the mp3's!
    Does anyone know if there is a max file size card the sat nav can read?
    I ask as you can now get 4GB cards!!!
    Aug 2004
    Aberdeenshire
    740
    I'm sure that I read 512MB somewhere. Someone more knowledgeble will be along shortly . . .
    Jul 2006
    160
    Quote Originally Posted by Macduff
    Oh I so hope you are wronge
    simonwjones's Avatar
    Aug 2005
    staffs uk
    351
    sd card sizes
    Im pretty sure that 2gb cards work fine in the RNSE, but you must use decent makes, Sandisk etc
    Simon
    Sep 2005
    Worksop, Notts
    97
    I currently have a 1Gb and a 512Mb in mine and they work fine. I have also been told that 2Gb work perfectly, but you should stick to quality brands as suggested.
    I've heard 4Gb work, but for the cost, you're better off buying 2 x 2Gb.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,534
    I use 2 4GB SD cards and 1 2GB SD card.
    The RNS-E has a limit of 512 files plus folders on each SD card, so unless you use a high bit rate (I use 320kbps) you will reach the limit of the number of files before the card is full. I get over 30 CDs per 4 GB SD card, so I have the equivalent of 75 CDs on 3 SD cards.
    Some, mainly older, RNS-E were VERY fussy about the SD cards they would work with - I've tried both normal and high-speed cards. My first RNS-E (HW version 047) would only work with high-speed cards, but my current one (HW version 070) is happy with just about anything.
    Jul 2006
    160
    Everyone thank you very much!
    I'm off to buy 2 x 4GB cards then!
