Chris NottVolks Autos
Results 1 to 16 of 16
    mattyboy199's Avatar
    Nov 2005
    UK
    1,678
    More phatnoise questions / problems
    1. I installed the software on to my PC no problem, plugged the cradle in & no power at all (its a uk version). I decided to try a few different ac adapters to identify the problem, it seems the AC adapter is the problem. I tried a few the adapters & the only one that works is a US robotics one that is 18v (is this what i should be looking at ? volts) all others dont seem to be powerful enough even the adjustable one i have which didnt work on any settings (well light both lights).HELP !
    2. I begun to organise my music have noticed not all albums etc will display in the same order as on my PC ? I see you can change order setting using options but will i have to edit all track, genre, artist, title if their incorrect or similar. Say for example i have a mixed cd which is mixed into the following track & on track change the track is different ?
    Any would be TOP
    thanks
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    simonwjones's Avatar
    Aug 2005
    staffs uk
    344
    Dont know if its any use but this is how I do sort mine
    I create a playlist using the name of the artist or compilation name and then simply dump amy relevant tracks into this playlist. This way you dont have to bother with any of the MP3 tag id's etc.
    then simply choose CD 2 from the control (playlist) and it read the name of the playlist to you, which will infact be the name of the artist or compilation.
    Simple but works a treat
    Just checked the power supply on mine, it a multifunction one from the states. The power is set at 12v and the transformer is rated at 18 watts
    you will probably find that most multi adapters wont give out enough power.
    Hope it helps
    Simon
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    If you bought of Ebay it will be USA spec and they will have changed the adapter for you.
    Your right about the quality of the PSU it’s got to be capable of a 1000mA & regulated that’s the important bit (unregulated causes problems with the hard drive).
    9V will power the USB (it does on mine) but you will have problems if you go below 1000mA & unregulated it will power the cradle but not the hard drive in the DMS.
    The AC to DC adapter specifications are as follows:
    Find a "regulated" power supply; this means its voltage is always the same regardless of the load current. Transformers do not fall into this category.
    Output (7.5 - 12V DC), 1000mA
    The plug specifications are:
    2.1 mm inner diameter, 5.0 mm outer diameter, 9mm sleeve, center positive
    I got mine from maplin
    http://www.maplin.co.uk/Module.aspx?...l&doy=14m3
    you can also update the software to media manager for free from Phatnoise
    http://www.phatnoise.com/products/software
    or straight to download (big file) below
    http://www.phatnoise.com/products/so...M_3.92_WWW.exe
    Nov 2005
    UK
    1,678
    yeah the adapter i have (US robotics) is rated at 18v & 1000Ma like you say the cradle powers up with other adapters but hasnt enough power to allow the DMS drive to actually run. Will the 18v have an effect on the DMS is it to much ?
    Matt
    wanted for 8L S3:
    Milltek system
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    The specification I gave you for the adapter is direct from Phatnoise & they recommend no more than 12 volts.
    However the maximum limit of the circuit set by it's components is around 25 volts.
    Someone ran a test on the cradle and came to the conclusion 15 volts was a safe workable limit anything over and potential problems could exist (but this figure was not set in stone).
    The cradle, DMS hard drive and controller are not that cheap to replace if it goes bang & 9.99 for a new PSU is not that much for piece of mind.
    So at 18 volts it’s your call.
    Nov 2005
    UK
    1,678
    Right guys got my cd cable today, it has the blue plastic block connector is but i have the large black one rather than the split in my car. Whats the easiest way to remove the pins from the connector block ?
    Matt
    wanted for 8L S3:
    Milltek system
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    It is not that easy you need a special tool (or a lot of patience with a paper clip / pin).
    Option 2 is to order replacement pins or pins with wire from an Audi dealer.
    I used pins with wire they cost 1 each. They are a wire with a pin on each end cut the wire in half and solder onto your cable you will need 5 which will be enough for ten wires.
    Female pins with wires Audi Part# 000 979 131 :-: 000 979 131A (0.5 mm wire ‘A’ means gold pins) or 000-979-019; (1.0 mm wire )
    Female Pins only with no wire that you crimp on the end of a bare wire Audi Part# N-103-357-06 or N-103-358-07.
    Nov 2005
    UK
    1,678
    from what i can see the protruding bits on the side of the pins are what locks them into the connector blocks. Shuould nt be to difficult to remove may take while though.
    wanted for 8L S3:
    Milltek system
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Yes your right & that’s what I started to do then I lost patience (pin in finger once too many).
    For some reason (big dumb hands) it did not work as I hoped so I thought sod it for 5 I will buy the wires.
    At least you know if you get stuck or damage them you have another option.
    Nov 2005
    UK
    1,678
    surely the pins that crimp on are the easier method though, just cut the block connector off & so on.
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,678
    right i managed to get one pin out pretty easy i thought, i m gonna do the rest later. Please confirm if i m right in saying that i ll need to record the colour of wire to each pin number socket. The wires seem to be different colours to the diagram i ve got so i would have thought same position but just different colours.
    wanted for 8L S3:
    Milltek system
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Quote Originally Posted by mattyboy199
    Yep your probably right.
    When I first did this it was a while ago and getting hold of the part numbers was not easy did not find the ones for the pins until after I had ordered the wires also I was making an RCA plug adapter which need the wires attached.
    As far as the cable colours if its not a genuine Audi cable then the colours could be different so your right same position different colour is the way to go.
    Nov 2005
    UK
    1,678
    Timps, you ve been a great help much appreciated.
    Matt
    wanted for 8L S3:
    Milltek system
    Nov 2005
    UK
    1,678
    Installed my cd cable last night & to my surprise everything worked fine first time round. The only problem i have now is where i should install the box & how.
    The area above the sub seems to be aboout an inch or 2 too small either way round unless i cut the casing or cut the covering panel that clips in. From pictures i ve seen of other installations i thought it was possible to fit the box in this area, its seems i have alot of stuff, cables & circuit boards packed into this area. Once again any help would apprciated
    Matt
    wanted for 8L S3:
    Milltek system
    cocain's Avatar
    RAA RAA like a dungeon dragon!
    Aug 2004
    The Sticks
    155
    respect to you guys you got time. i just bought an ipod and adaptor for my Alpine head unit and it took me 7 mins to install and i can operate it from my head unit. Looked at phat noise but the ipod more versatile.
    Nov 2005
    UK
    1,678
    You would be very surprised mate, after installation its the best thing i could of done. I love it.
    wanted for 8L S3:
    Milltek system
