Sky InsuranceEM Tuning
Results 1 to 10 of 10
    mattyboy199's Avatar
    Nov 2005
    UK
    1,689
    Phatnoise questions
    Hi guys
    I ve just purchased a phatnoise i expect delivery within the next fews day & seeing as your all experts in this field i have a few questions, sorry if their re-peats.
    1. I dont have a cd changer cable & could someone indicate the correct cable for a Symphony II unit.
    2. I ve read some that using a mouting bracket can interfear with the sound quality buzzing etc is there a remeady for this i read that someone used 3M pads & placed the box on their sub.
    3. CD cable installation whats the best route ? i was thinking go in from the passenger side of the dash to the HU then run the cable under the door trim sills behind the rear quarter panel card & into the boot.
    4. I dont think i ve missed anything but any further advise would be a great help cause i m pretty clueless i couldnt even remove the boot trim the otherday.
    Matt
    2002 Dolphin grey S3 - Sym2+bose, heated leather, ally mirrors, R32 ARB's with superpro, Jabba stage 2 map, TFSI coils, Samco TIP, Forge DV & privacy glass
    2010 Green Kawasaki Ninja ZX6R - Akrapovic baffleless race can, LED cluster & HID's
    wanted for 8L S3:
    Unmarked grey rear bumper panel
    Milltek system
    Oct 2003
    up north...
    767
    you can get a buzzing if the phatbox touches the metal cd mounting - i used very thin mounting foam and found nylon screws
    you need a standard audi changer cable - either oem from a stealer or from ebay or such like -
    ideally you could run the cable to the trunk cubby hole and put the phatbox where the oem changer should be - alternatively take the phatbox out of the large aluminium case which leaves a very small box that can easily be fitted into the back of the glovebox
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Nov 2005
    UK
    1,689
    wanted for 8L S3:
    Milltek system
    Feb 2003
    43
    Not on mine, I had to insert the pins into the plug that was already there (I bought the audi cable).
    Nov 2005
    UK
    1,689
    oh god dont say that is there instructions, whats wrong with cable above ?
    Matt
    wanted for 8L S3:
    Milltek system
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Instructions are here http://www.phatnoise.com/audi/downlo..._PhatNoise.pdf
    If you have bought the one with the plug attached it’s the same cable but you will have to remove the pins from the plug unless you have the split green and yellow plug at the rear of the radio.
    If you have already ordered you might be lucky some come with the blue plug separate.
    Feb 2003
    43
    Yup, you (well I did anyway) have a connector that goes in there and takes up all the space, but it is very bare. So you just poke all the wires of the new cable into the existing connector and plug it back in. 10min job (only takes that long because of paranoia of getting it wrong).
    Nov 2005
    UK
    1,689
    dont suppose you could advise what colour goes where i ve looked at instructions but cant really understand what number pins are what or in which order they go in.
    wanted for 8L S3:
    Milltek system
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    You only need to insert the pins in the existing connector if you have CONCERT or CONCERT 2. Symphony will be fine since the socket this plugs into is empty.
    Porsche 997 Carrera 4 S - Black, Sport Chrono, Sport seats, PCM, Nav, Tel, Park assist and rear wiper (Yes!, its an option!)
    2012 Audi Q7 Sline Plus - Daytona Grey ,Nav+, Wheel upgrade, Storage and tow pack.
    Gone -2007 S5 4.2 ,2008 S3, 2007 TTC 3.2, 2007 RS4 Saloon, 2004 S4 Saloon, 2006 A4 2.0T Sline SE,2002 A3 3.2 Sline, 2001 A4 1.8T,2001 Boxster, 1983 911SC,1992 Corrado G60,1988 GTi.
    (Vag com owner)
    timps's Avatar
    Shakersville
    Oct 2005
    Shakersville (Bury)
    235
    Never done a Symphony II but the plug you are dealing with is (multi pin connector I 20 pin- black) on page 10 of the instructions the colour code for the wires is page 7 (step#18A) . If it is one single plug you will have to place the wires in if it is the split connector (Green/yellow) (or no plug)the blue plug will push straight in at the side.
