EM TuningAH Fabrications
    darko's Avatar
    Dec 2004
    london, uk
    272
    A3 / S3 door speaker adapters ?
    how easy is it to make these yourself from MDF or similar ? failing that where can you get some decent quality ones ?
    Mar 2006
    london/ essex
    114
    autoleads make them out of abs plastic any good audio shop can get them for around 12 or ha#ords can but you will pay more.
    sneaky silver s3.
    Jun 2003
    World of my own
    9,813
    It's fairly easy out of MDF though you need both 6mm and 9mm thicknesses if you are mounting 5.25" components (or a router).
    MDF also does eat into the mounting depth compared to plastic ones. But I don't know anyone who makes good plastic ones that fit properly (certainly not Autoleads).
    I've got some templates if you want to make your own.
    PM me with your email address.
    Cheers, Andy
    darko's Avatar
    Dec 2004
    london, uk
    272
    pm sent, btw - why do you need to use a different thickness ? i have the focal 130V slim so im hoping clearance should not be a problem... i have a long drive on saturday to france so need to get some music before then !
    Jun 2003
    World of my own
    9,813
    Template PDF sent over.
    9mm to clear the door card mounting posts, then 6 or 9mm to fit the new speakers. 6mm just gives you a few precious mm's on the depth which overall is about 60mm including the adapter, but depends on the speaker you are fitting as some (like the Infinity kappa's) stick out a mile beyond the speaker cage, so you'd have to use 9mm to get clearance.
    Pete69zx
    PM sent to AndyMac.
