Template PDF sent over.
9mm to clear the door card mounting posts, then 6 or 9mm to fit the new speakers. 6mm just gives you a few precious mm's on the depth which overall is about 60mm including the adapter, but depends on the speaker you are fitting as some (like the Infinity kappa's) stick out a mile beyond the speaker cage, so you'd have to use 9mm to get clearance.
