Chris NottEM Tuning
Thread: RNS -E Problem
    Leetaylor's Avatar
    May 2004
    77
    RNS -E Problem
    Hi
    Now then, is it me being stupid, or is the sorting of tracks a complete nightmare on the SD card to enable playback on the unit.
    I hava a SD card (1G) of which i want to put quite a few albums, so when i copy and paste the tracks onto the card on my PC they are fine, all in order with the full compiment of tracks.
    However, when i put the card in the reader slot in my car everthing changes!!
    The unit takes it upon itself to re-arrange everthing into alphabetical order, or if the tracks are numbered, i.e 1-20 per albumn, all the 1's go together then the 2's etc etc!!
    Also the songs are all in Mp3 format, and show up on the PC reader, but the RNS cannot read all tracks, there are approx 5-10 missing per albumn.
    Is anyone else experiencing stuff like this, and is there a software programme to sort this, otherwise i think i'll have to purchase a CD changer!!
    Lee
    Oct 2003
    up north...
    767
    firstly use separate folders for each album using a descriptive short name
    secondly make sure all mp3 files use cbr - constant bit rate - it will not show or play variable bit rate encoded files
    check the mp3 file tags are present using the same format - i usually use id3-v1 and id3-v2 together
    finally rename the files with a leading zero and the track number at the start of the name - eg '01 track name 1' then '02 track name 2' etc
    only put a max of about 450-480 tracks on an sd card - there is a limit of 512 files and folders in total.
    TT-RS 410hp revo
    Fiat 500 1.3 tdi 120hp
    A3 8P 2.0tdi 240hp Autograph Cars
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Volvo 850 T5 300hp BSR
    Fiat Punto GT 130hp
    Lancia Delta Turbo 185hp
    Lancia Beta Coupe 122hp
    Mini 74hp
    Oct 2003
    up north...
    767
    use cdex freeware to do any ripping and winamp to do any name / tag conversion
    TT-RS 410hp revo
    RS4 B5 520hp MTM
    S3 8L 345hp MTM
    Fiat Punto GT 130hp
    Mini 74hp
