Chris NottVolks Autos
Results 1 to 12 of 12
    vanbasten's Avatar
    Jun 2006
    Ballymena, Northern Ireland
    45
    Newbie Confused!!
    Ok, so I've decided to change my original bose concert headunit for a sony one with cd changer.
    However, on buying the autoleads wiring adapter and connecting up my stereo have found that although power is going into the unit as it starts whirring when connected, the headunit does not have any life about it.
    Any one know why this would be?
    Apologies if this has been covered before but i've tried searchin the forums and cant find any relevant information.
    Jun 2003
    World of my own
    9,813
    Most newer Audi looms don't have an ignition on feed, the 3rd pin on the bottom row, so you'll need to connect the yellow ignition on power on the Sony to the perm live on the Audi loom. Easiest way is to splice the yellow to the red on the Sony loom before the ISO connector then you don't have to modify the Audi loom.
    vanbasten's Avatar
    Jun 2006
    45
    Quote Originally Posted by AndyMac
    Thanks for answering AndyMac, I'm using the autoleads adapter to join the audi looms to the sony loom. What wires should be spliced?
    Sorry for asking such obvious questions but is my first time trying to install an aftermarket headunit.
    Jun 2003
    World of my own
    9,813
    You have 2 power connections for the Sony, one for permanent 12v to keep all your presets live, and one for turning the HU on/off usually with the ignition.
    Red is usually perm live, yellow is usually ignition on live.
    The industry standard for HU's is to use a Black ISO power connector, with the perm live top right (looking at the back of the Audi connector where the wires go in with the locking pin on the left), earth bottom right and ignition on 3rd from right on the bottom row.
    So if the Sony has an ISO connector for power then it'll be expecting the this pinout on the Audi loom. Look at the Audi loom and check that there is no ignition on cable 3rd from right on bottom row.
    If this is the case then the HU is getting no power to switch it on.
    So the yellow feed to the Sony is not connected to anything, cut it and connect it to the red perm live wire (top right on the Audi loom, top left on the Sony end). It would be so much easier with pictures.
    vanbasten's Avatar
    Jun 2006
    45
    Again, Andymac, thanksfor your patience, i will try it tomorrow and see if i can make sense of it.
    Jun 2003
    World of my own
    9,813
    If you're still unsure then post a pic of the Sony loom together with the Audi loom
    vanbasten's Avatar
    Jun 2006
    45
    I checked the looms and found that as you said, there was no no ignition on cable in the audi loom.
    Will patch it in to the permanent live feed later today.
    vanbasten's Avatar
    Jun 2006
    45
    Well, patched the 2 live feeds together and and headunit now working fully.
    Cheers Andymac for all your help
    Nov 2005
    lothian
    181
    I always thought the yellow was the perm.....
    bluetybo's Avatar
    Feb 2006
    Edmonton, Alberta, Canada
    15
    yes, Yellow is constant and red is acc, wire them together, just make sure you remember to turn your HU off when you turn your car off.
    06 A3 2.0 FSI, DSG, Brilliant Black, and I live in Canada, brand new to North America, I LOVE IT.(so far)
    vanbasten's Avatar
    Jun 2006
    45
    Yeah, thats the only down side, no auto on/off with the ignition.
    Jun 2003
    World of my own
    9,813
    You can wire up the ignition on feed to the fusebox to pick up the switched feed, but I could only find a full ignition on rather than an accessory on feed. So the HU turns off with the engine rather than when you take the keys out, so I didn't bother. The proper accessory feed is usually labelled as Radio (S-Kont) but this wasn't listed on my B6, and checking each fuse none of them provided 12v without the engine running, or full ignition on.
