EM TuningVolks Autos
Results 1 to 10 of 10
    bluetybo's Avatar
    Feb 2006
    Edmonton, Alberta, Canada
    15
    How do I get 2 awg wire through the firewall?
    Hello, I was wondering if there are any holes I can use to get my power wire (for my amp) into the car from battery. Its 2 gauge wire, I cant seem to find any holes in the firewall. Any help is Greatly appreciated. Thanks.
    A3 2006
    06 A3 2.0 FSI, DSG, Brilliant Black, and I live in Canada, brand new to North America, I LOVE IT.(so far)
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    not for 2 gauge.....jesus thats thick !
    i have a feeling you may be making your own holes for that one !
    Anito's Avatar
    Dec 2003
    Chester
    429
    Have a good look around, there is normally a lug somewhere you can make use of.
    bluetybo's Avatar
    Feb 2006
    15
    thanks, has anyone used thicker wire when going through the firewall? Pics would be nice, is it easier to go from inside car to find a hole?
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    No idea on the B7... but on my older B5 (2000 model) the ECU box sits near the firewall. I got 0 Gauge wire through the back of the ECU box. I had to take the cover off, run the power cable through there and down into the footwell.
    Facelift Imola S4 | Custom: K04's, Tubular Manifolds, 3" DPs-> 2.75" Catback | FMIC | H&R Coilovers + ARB's | Brembo 8-Pots | SS + DTS | 503HP/475lbs/ft | 1800W RMS
    Sold: Audi A4 (B5) 2.8 Quattro | Ivory Pearl
    Melted: Corrado - IHI 1.8 20vT: 343BHP
    ash_s3's Avatar
    Aug 2006
    Shrewsbury
    1,005
    why are you using 2awg cable? are you running about 12 amps or something??
    4 or 6awg is quite enough for most installs!
    Jun 2003
    World of my own
    9,813
    Yes I would also question the use of 2awg, this is only required for 2.5kw of power. Bearing in mind no such amp exists within a reasonable price range why make life difficult for yourself?
    2awg won't easily run along the door channels either.
    ZeroK66's Avatar
    Jun 2004
    Devon, UK
    246
    So 0AWG was overkill for my install then *blush*
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    depends on distance, and currant (pull) of the amp(s) basically 4awg over a 5metre length is good for 1000watts RMS if its of a lowish currant
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,500
    I am in the overkill catagory then, i have "0" Wg in my B5 too
