Monster MotorsportEM Tuning
Results 1 to 9 of 9
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    S3 - Audio Switched Live Feed
    Hi all
    I'm in the process of fitting an after-market Head Unit with the autoleads PC9-401 adapter, the the S3 only has a permanent live feed to the radio wiring (as far as I can see).
    Where can I pick up a switched (1st click) live feed from, any idea's, I don't want to have to turn the radio off manually every time I leave the car?
    Thanks.
    Col
    Jun 2003
    World of my own
    9,813
    If there isn't one on the power ISO connector for the radio (yellow with a red stripe) then you'll have to pick it up from the fuse box. Look for fuse labelled Radio S-Kont in the manual, fuse 30 IIRC.
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    there should be both permanent and switched wires to your iso block.
    Permanent is there to keep the radio stations/settings saved when you turn the car off.
    Switched ignition is obviously there to turn the radio on when the ignition is.
    From what I can remember, you should have a red wire and a yellow wire going into the iso block. On your aftermarket headunit, you need to swap these over, ie:
    red to yellow
    yellow to red.
    Jun 2003
    World of my own
    9,813
    Not necessarily, Audi stopped using ignition on feed on all models at around 2000/01 and they all now use the CANBUS to tell the HU when the ignition is on/keys out etc.
    neil.c's Avatar
    Senior
    Apr 2004
    leicestershire
    564
    So it looks like you are going to have to locate one at the fuse box then
    99 S3 Absolute red
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    Question
    Thanks all, off to the fuse box it would be........
    If only I could get a decent FM signal from the aerial!!!
    So far I've tried an autoleads 'powered' connector to the standard aerial, no joy, and an autoleads 'powered' connector to the small aerial lead that's usually connected to the middle rear of my Concert HU, still no joy.
    I've even 'bodged' them both together to connect to the new HU, but then the signal seems too strong and I just get interferrence (especially with the engine running).
    I'm considering a standard screen mount amplified aerial, but think it will look messy!
    Any idea's??
    Jun 2003
    World of my own
    9,813
    I'd try a different brand of aerial amp, Autoleads products are traditionally shyte although can't see how even they could manage to botch a simple aerial amp.
    Bit confused on how you managed to connect the amp to 2 different aerial leads. The fat aerial lead plugs into the amp, the amp plugs into the HU then you need to connect the flying lead off the amp to the power antenna output on the HU to give it power when switched on. There is no other configuration and the small aerial lead connected to the middle of the concert rear is just an earth lead to the chassis so how you've managed to include this in the mix is a mystery.
    Have you tried uing a small screwdriver directly on the HU aerial input (centre core) as this should provide perfect FM reception - just to check the problem is with the aerial/amp.
    col6821's Avatar
    Feb 2006
    Warwickshire
    175
    Smile
    Cheers AndyMac, I'll try the screwdriver trick next.
    The smaller aerial connection still looks like coax and Autoleads make a booster for this as well PC5-137 (purchased from bluespot.co.uk). The usual aerial booster is PC5-52.
    Basically, I've chopped the coax of both boosters and joined them together, terminating in a traditional aerial connector ready for the HU, as all the previous configurations just didn't provide consistent results. Interstingly, the Concert HU doesn't receive reception with either cable disconnected.
    If the screwdriver works, I'll try an alternative booster supplier.
    Thanks again for your help.
    Jun 2003
    World of my own
    9,813
    Well I've never sen that on an A3/S3. I don't think joining them together is a good idea, they are obviously seperate for a reason. If there is a second aerial then it is likely to be one for AM and one for FM, so you only really need the main one.
