JMB RetrofitsAH Fabrications
    jbw
    Nov 2004
    Worcester
    193
    Front speaker install
    Can someone help me out with instructions on how to remove the front door cards? I've searched but I can't seem to find the info amongst the 750 search results. [img]/ubbthreads/images/graemlins/confused.gif[/img]
    Also I've got some maystar speaker adaptors to fit my Kappa 50.5 components in my a3 but I can't seem to get them to fit over/around the speakers? Are 50.5's larger than normal speakers or am I being a spoon?
    Many thanks,
    jbw
    Jun 2003
    World of my own
    9,813
    Re: Front speaker install
    Remove the 2 visible screws either side of the door card, then remove the one behind the grab handle. Push down on the plastic cuff inside the grab handle to reveal the 2 main screws. Remove these and then, with the window down, lift the whole door card up and out. If it's the 1st time its been out then it'll be quite stiff.
    The adapters fit on the front of the speaker, but you need to screw them to the door card first, then mount the speaker to the adapter. I wouldn't be surprised if they don't fit properly, I haven't come across any that do apart from home made MDF ones.
    jbw
    Nov 2004
    Worcester
    193
    Cheers Andy! [img]/ubbthreads/images/graemlins/smile.gif[/img]
    jbw
