Chris NottAH Fabrications
Thread: Upgrade!
    owdgit's Avatar
    Sep 2005
    UK North West
    112
    Upgrade!
    I know I put a request for a simple upgrade but I give in and have decided to spend a little more.
    What size component speakers fit the front and rear doors on an 2001 A6 saloon?
    Is there a replacement HU that will allow the audio steering wheel controls to still function with the replacement HU or is there a 'magic' box of tricks that will do this?
    Ta again.
    Jun 2003
    World of my own
    9,813
    Re: Upgrade!
    I think they're 6.5" on the A6 with 1" tweeters, unless you have the Bose upgrade.
    I think only Blaupunkt do interface harnesses for the steering controls, but I maybe wrong. Their HU's are certainly the only ones I've come across that use the bizarre mini-ISO connectors for the pre-outs and CD changer, just like the Audi ones, so it's a straight plug & play from a wiring point of view. I guess this is derived from the fact that they used to make all the head units for Audi's (pre-'99) before Matsu****a took over, but still use the same connectors.
    Blaupunkt certainly list an adapter cable for the A6 (97-04) for the steering wheel controls, part number 7 607 621 145 for use with most of their HU's and they are one of very few manufacturers who do a decent all in one DAB tuner (Woodstock DAB54), which I currently have fitted in my B6 A4 and can't rate highly enough. It has Aux inputs for iPOD, plays MP3 CD's and can even record off air onto SD media cards. A snip at 299.
    Also the A6 uses a seperate amp for the rears and sub, but when I tried linking into it I had to fade quite a bit to rear in order to get a balanced sound. By passing the rear amp and using the rear speaker output from the HU cured this, but the sub was then too faint, so ended up ditching the plastic sub and installing a seperate amp and JL Audio sub in a proper MDF stealth enclosure. But TBH you can get quite a good sound just from the cabin speakers as they are mounted in the doors rather than on the flimsy door cards.
    owdgit's Avatar
    Sep 2005
    UK North West
    112
    Re: Upgrade!
    Cheers AndyMac, looks like you are the audio guru on here.
    owdgit's Avatar
    Sep 2005
    UK North West
    112
    Re: Upgrade!
    Any opinions on these for the front and rear doors? Or what would you reccommend?
    Alpine SXS-1757 Components cost around 59.00
    Ta
