Monster MotorsportBadger5
    Sep 2005
    U.K.
    Symphony II to RNS-D In A4 B6, Info please
    I have purchased a RNS-D unit (with the correct part No!) and wondered if i would need a CANbus to enable the Dis to work, or for once, would i be lucky and be able to "plug and play"?
    If i do need the CANbus, where from and how much.
    Any help would be appreciated, thanks
    imported_craigyjp
    Re: Symphony II to RNS-D In A4 B6, Info please
    By CANbus, what you really mean is a CAN gateway module/ TMC tuner. And yes you will need one to get the DIS to work with an RNS-D.
    What it basically does is convert the Bosch can of the RNS to infotainment can for the DIS.
    It also provides an additional tuner for TMC information.
    If you had bought an RNS-E, it would have been plug and play.
