Monster MotorsportVolks Autos
Results 1 to 8 of 8
    Mar 2006
    Culmstock, Cullompton, Devon
    67
    Concert Volume Control Problem
    The on off button which doubles up as the volume control does not always work properly on my 98 A4. More often than not a tweak of the volume knob to turn the volume down a level results in the speakers pumping out noise at full volume!
    Is this a common problem? Is it easily fixed or do i need to rip it out and get a new one?
    Jul 2005
    2,488
    Re: Concert Volume Control Problem
    There is a fix, but unless your handy with soldering surfance mount components, it'll be a new one i'm afraid.
    The problem you're experiencing is very common, and a fate destined for all early concert owners.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,347
    We've all had it!
    Missed gear
    Jan 2006
    Kent
    385
    Where can I find some more details of the fix ?
    Jun 2003
    World of my own
    9,813
    Here's the detail of the problem:
    Volume Problem
    But unfortunately not the solution
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,347
    [ QUOTE ]
    [/ QUOTE ]
    The only known fix is a new HU from Ebay.
    Nov 2005
    lothian
    179
    There is a company called OE electronics that can fix this problem. I had mine done but it cost 68 quid plus the VAT...
    (01249) 817370
    Hope that helps.
    Cheers.
    Mark.
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    very common, it usually happens when the weather is cold (so im told)
    Its done the job woking me up 1st thing monday morning when i used to drive the S4 i can tell you !
