Volks AutosSky Insurance
Results 1 to 8 of 8
    dik
    dik's Avatar
    Aug 2003
    South Wales
    125
    Symphony II and Dension Icelink Plus
    Hi All,
    Was just wondering if the head unit on an A3 Sline TDI - symphony II BOSE (in dash cd changer,etc..) will support my Dension Icelink (currently connected to me S3 concert HU?)
    The Concert has an ext cd changer, but the Sympony II is one unit?
    Can it be done?? or is my icelink useless?
    Dik
    Jul 2005
    2,488
    Re: Symphony II and Dension Icelink Plus
    it can be done just as easily as your Concert, and you will retain the single CD too.
    imported_ZeroK66
    Not so sure about that... if your A3 is the next generation it may not work...
    dik
    dik's Avatar
    Aug 2003
    South Wales
    125
    Cheers madvw i'll look into this a bit more, Will I need a different adaptor for the icelink?
    imported_ZeroK66
    Take that back... its only A6 & 8 that dont work after 2003
    Jul 2005
    2,488
    [ QUOTE ]
    [/ QUOTE ]
    it depends on what connector you've got already. If its the same as my S3, i was supplied with the VAG-20 pin piggy back connector - not the VAG-8 Pin connector (blaupunkt style mini-iso). This way, the ice-link harness plugs into the HU, then the OEM iso plugs into the ice-link harness.
    You just need to take a look behind your new stereo to see if it uses the 8-pin or 20 pin connector, and buy the appropriate cable, which IIRC is about 20.
    I can only see the differences between the 8L and 8P concert 2's being to do with the DIS and facia changes, but as the ice-link only connects to the CD-changer wires, i can't see a reason why it wouldnt work? anyone else?
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    it will work. Symphony 2 has in built 6 cd and the external cdc connector is empty so you can plug the ice link plus in there. I had this setup on my old a4.
    dik
    dik's Avatar
    Aug 2003
    South Wales
    125
    cheers for the info guys, am picking the car up on saturday and need my tunes asap..
    thanks again
    dik
