If I were to buy a 1999-2000 A6 with standard Audi sat-nav and TV fitted is it possible to upgrade the HU with a newer version (DVD based) without to much hassle.
I would say that you probably have a C, so upgrading is difficult unless your cluster has 3 connectors on the back and not 2. You need the green/blue and grey connectors for a can bus dash. If you have that then you can probably install and RNS-E without to much trouble. If not then you would need a can bus adaptor and you would lose the DIS.
