Monster MotorsportBadger5
Thread: Arial repair
    Sep 2012
    23
    Arial repair
    Go a4 b6 but the reception is very bad
    used booster arial still same anyone know where the aerial
    is located and is it a easy fix.
    thanks
    27,121
    Antenna system isn't suited to aftermarket systems very well tbh, there are adapters out there, with varied degree of reception quality, but no guarantees, so you will either need to fit an aftermarket antenna system or maybe consider oem head unit route.
    Sep 2012
    23
    Oem is to old it started to get bad a few months ago
    Is it easy to fix the oem aerial??
  1. Repairs
    By lsoexped in forum TT/TT-S/TT-RS Forum
    Last Post: 12th November 2003, 13:51
  2. Arial connection
    By gburgess in forum In-Car Entertainment
    Last Post: 1st November 2003, 18:32
  3. Stone Chip Repair
    By djmotorsport in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2003, 13:59
  4. Repairing RS TT wheels
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2003, 15:51
  5. Gearbox Repaired!
    By Joshie in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th February 2003, 08:59
