Results 1 to 10 of 10
    Jan 2014
    Running amp off of bose amp?
    Been searching for days and still no luck.
    Im im looking at upgrading my sub in a 2007 a3 (full bose)
    was thinking is it possible to use the output for the sub to run a separate amp? If not what's my best option..thanks.
    Dec 2006
    barnsley
    1,013
    if you mean use the wiring then its not really worth doing as the size of the wiring limits what amplifier you can use
    you could look at installing an amplifier and running it from the 12 volt socket like this
    I now have Bass
    the only other option is to install new wiring from the battery itself and if your going to that effort you may as well install an amp capable of running whatever you wish
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jan 2014
    I mean taking the signal used for the oem sub and running it through a converter to a new amp? Or just changing the sub and leaving the amp?
    Dec 2006
    barnsley
    1,013
    there isnt really a chance to upgrade just the speaker as the amp itself isnt powerfull enough to push anything else so as you would notice
    the signal from the headunit is at line level so doesnt need converting
    Jan 2014
    Quote Originally Posted by dualmono21 View Post
    Ok thanks. So does that mean I can just cut the end off of an RCA lead and crimp them to the sub out puts. And run another amp like that?
    Dec 2006
    barnsley
    1,013
    you could yes but you can also buy a convertor which gives you a sub out at the headunit
    you simply connect an rca to it and you can put the amp wherever you like
    Jan 2014
    So would the signal from the bose amp (powering the sub) be sufficient to power an additional amplifier?
    Dec 2006
    barnsley
    1,013
    yes the signal is sufficient strength
    however the power wiring and everything else isnt
    Jan 2014
    Thumbs up
    I have new cables already run
    Dec 2006
    barnsley
    1,013
    might have been better running an rca cable when you ran the others as the well
    the std audi or bose lead is unshielded so can pick noise up
  1. A4 B5 - Can I run a sub and amp off my Symphony?
    By Dans-first-Audi in forum In-Car Entertainment
    Last Post: 11th June 2009, 19:05
  2. B5 Bose amp pin outs for Dunk
    By AndyMac in forum In-Car Entertainment
    Last Post: 3rd March 2007, 13:03
  3. Will Bose amp work in non-bose S3?
    By C_Audiboy in forum In-Car Entertainment
    Last Post: 13th May 2006, 08:48
  4. BOSE Amp
    By Naresh in forum In-Car Entertainment
    Last Post: 11th February 2005, 16:38
  5. Replacing Bose Amp for Main Speakers
    By rweerasi in forum In-Car Entertainment
    Last Post: 12th July 2004, 14:34
