Chris NottMonster Motorsport
    jamesey's Avatar
    Sep 2013
    derbyshire
    96
    new headunit on amped bose , popping when i touch anything. a4 quattro b6
    hello ive got a audi a4 quattro with a fully bosed set up in it , ive put my pioneer headunit in and it all works fine apart from everytime i turn radio on , chance cd trtacks , mute etc etc im getting a very loud pop , would a earth loop connector do the trick there must be someone thats had the same issue , ive got 2 pre outs connected up to my headunit as its the fully amped system.
    if not what will stop the bang its doing my head in.
    thanks
    AK47UK's Avatar
    Sep 2013
    397
    Ground loop isolator on each RCA should sort it for you mate.
    8P3 '10 1.8 TFSI 3DR Black Edition S-Line
    Dec 2006
    barnsley
    1,016
    pioneer head units have an unusual earthing system
    which can occasionally go wrong and give these kind of faults , its usually caused by a blown earth earth track on the rca outputs
    i couldn't be 100% that a ground loop isolator will work in this situation as it usually used to help equipment which is earthed in different places and receiving different voltages .... try it but if it doesn't work then youll either need to send it away to be repaired or have a go at replacing the tiny fuses yourself
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    AK47UK's Avatar
    Sep 2013
    397
    I didn't realise there was a known problem with pioneers, my non-pioneer needed the isolators.
    Dec 2006
    barnsley
    1,016
    its not a problem if there working o.k , however over the years its been proven the grounding method pioneer use is not as robust as other manufacturers unfortunately
    Ay3
    Apr 2011
    Ground loop isolators from maplin sorted mine, only issue was getting them in behind the unit, they are huge! Ended up extending the cables out and fitting them behind the glovebox
  1. stock headunit, aftermarket subwoofer, pop when turned on
    By sliced in forum In-Car Entertainment
    Last Post: 8th November 2013, 13:32
  2. New Headunit Settings for Audi Bose?
    By wilko in forum In-Car Entertainment
    Last Post: 4th July 2009, 16:14
  3. New Headunit to replace Concert with Bose
    By wilko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th June 2009, 13:09
  4. Finally new headunit in!!
    By justin_1ss in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th April 2005, 02:54
  5. Changing the Headunit on a Bose system
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2005, 15:28
