JMB RetrofitsEM Tuning
    Apr 2013
    50
    Au-iIn lead for Concert tape/radio - doesn't seem to work.....
    I have a lead like below - a mini iso to 3.5 jack.
    When I use it to connect an ipod to the standard Concert tape/radio the Concert does not recognise that it is there when I push the 'mode' button to switch sources.
    My car did not have the CD changer fitted from factory so is that the problem? Does the radio need to be coded to 'see' any input through the cd changer rear ISO?
    Stu
    Dec 2006
    barnsley
    1,021
    could be the original input is not coded for that
    it may be possible to adapt the coding and enable the input
    do you have access to vcds ?
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Apr 2012
    64
    Have you tried pressing the cd button twice? I read you had to do that on some by listings?
  1. Audi s3 2000 bose concert tape stereo which lead
    By tiki2402 in forum In-Car Entertainment
    Last Post: 1st December 2013, 21:33
  2. Replies: 9
    Last Post: 22nd June 2013, 23:46
  3. Removing Concert 1 Radio Cassette
    By ajmackie in forum In-Car Entertainment
    Last Post: 13th July 2004, 07:18
  4. MOVED: Lead for VAG-COM
    By Grant in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2004, 15:01
  5. CD Autochanger for Concert II
    By a900ss in forum In-Car Entertainment
    Last Post: 11th February 2004, 10:06
