Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Dec 2011
    Somerset
    506
    Shallow mount 10" sub or regular ?
    The box is a sealed with15 L internal volume.
    A JBL shallow mount is recommending 14.15 L and a regular Kenwood requires 18.4 L.
    Shallow or regular for best result, and what would happen if the Kenwood went in the undersize box ?
    Dec 2006
    barnsley
    1,020
    if you put the kenwood in a smaller than normal box it will produce a slight hump in the frequency response
    but being as its a sealed unit it will still work quite well
    shallow mount subs dont have the power handing or capability of a normal sub as yet as they are still fairly new and being devolped
    if you can stretch to it a jl audio w0 should do everything you want
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Dec 2011
    Somerset
    506
    JL Audio 10W0 v3-4 are less than £61 at the moment
    But the JL also requires 18.4 L.
    I have found a regular sub that is a freak as it requires less internal volume than a shallow in its own line up and a Kenwood shallow.
    It's a Rockford Fosgate Prime Series R2D4 , requiring 16.71 L.
    What do you think ?
    Dec 2006
    barnsley
    1,020
    what amp is this going to run off ???
    Dec 2011
    Somerset
    506
    JVC KS-AX 3101
    Class D , mono block.
    1 X 250W @ 4 Ohms
    1 X 400W @ 2 Ohms
    Dec 2006
    barnsley
    1,020
    what kind of music do you listen to ??
    that amp will power the rockford or the jl just make sure you wire it up properly
    the rockford is a dvc sub so has two ways of wiring it
    Dec 2011
    Somerset
    506
    Thanks for your input.
    There is only 1 band I have every album...
    Metallica.
    Dec 2006
    barnsley
    1,020
    a kindred spirit been lucky enough to see them live a few times
    in that case buy the jl audio it will perform well on this kind of music
  1. front sub frame mounts
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2012, 23:18
  2. mounting sub and amp
    By Jay in forum In-Car Entertainment
    Last Post: 29th September 2006, 15:03
  3. AndyMac stealth sub mounted :-)
    By olekvi in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2005, 17:09
  4. It's that time of year again - insurance quotes?
    By ColinM in forum General Chat
    Last Post: 14th April 2003, 17:03
  5. Active Subs?
    By mramage in forum In-Car Entertainment
    Last Post: 12th January 2003, 15:19
