Badger5Chris Nott
    Apr 2013
    49
    A4 B5 standard rear amp - is it 2ohm stable?
    The standard amp on the rear speakers of a '98 B5 - any reason it would not cope with a pair of 2ohm speakers?
    Stu
    Dec 2006
    barnsley
    1,016
    some of the speakers which were fitted are actually 2 ohms
    but i wouldnt reccomend putting 2 ohm speakers on an amp thats only 4 ohm stable it will break it quite quickly
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Apr 2013
    49
    It's the non Bose setup, so I can only assume the speakers are 4ohm?
    I have acquired a pair of the Bose rear 'subs' which are 2ohm which I want to use to replace the standard speakers as my HU has an option for a low pass filter and bass booster on the rear speaker output.
    Stu.
  1. Power to rear amp in A3 8L
    By beanoir in forum In-Car Entertainment
    Last Post: 5th November 2011, 14:40
  2. Pass Side, Standard, Rear Parcel Speaker & Cover
    By 30vquattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd September 2011, 14:20
  3. Saloon rear amp
    By MarkWizard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th February 2011, 21:59
  4. Standard rear camber?
    By jm-baker in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2009, 15:21
  5. How to tell if you have a full Bose or only rear amped system
    By SteveTDCi in forum In-Car Entertainment
    Last Post: 27th March 2008, 18:26
