Monster MotorsportChris Nott
Results 1 to 7 of 7
Thread: Bose setup
    imported_alecblack
    Bose setup
    Can anyone tell me what i need to do to set up the Bose system on my car?
    Just now i have an old gamma radio but want to upgarde to a concert stereo but i keep hearing about a Bose setup. What do i need to set this up? do i need bose speakers, bose amp, bose head unit.
    Is the sound a good quality?
    cheers in advance
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    Re: Bose setup
    IMO you would be better of with aftermarket audio equipment
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    Re: Bose setup
    Its not that good anyway...
    Jun 2003
    World of my own
    9,813
    Re: Bose setup
    Yeah, Bose is pretty hopeless especially in the A3. And to retrofit one would be more complicated than installing an entire aftermarket system as all the wiring is different, it uses a 4ch amp, seperate sub & amp and all the speakers would have to be changed.
    Ideally go aftermarket, but if you stick to the Concert then just by adding a sub you can get pretty good results far better than the Bose setup. The sub is the key as even with the Bose setup the OEM sub is housed in a plastic box which gives you that signature woolly/muddy bass that we all aspire to.
    I do a custom stealth sub enclosure using a JL Audio sub which replaces the OEM unit and the transformation is pretty outstanding if I do say so myself.
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Re: Bose setup
    How much is one of your custom subs etc to fit a b5 s4 with standard concert. How difficult is is to fit, I guess you need an amp ?. Got any pics of an install on a b5 ?
    Jun 2003
    World of my own
    9,813
    Re: Bose setup
    A3/S3 only I'm afraid, you can get stealth sub enclosures for the B5 from Auto Acoustics. The only reason I did the A3 was that the exisiting sub was abysmal (Bose & non Bose) and no one did an off the shelf unit.
    B5 Sub
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Re: Bose setup
