JMB RetrofitsChris Nott
    Apr 2013
    49
    Audi OEM 13cm (5.25") speakers - what models have them?
    I am returning my A4 (1998 B5) stereo to factory as the wife will now be the user of that car so my better kit is coming out.
    I no longer have the factory 4" speakers but I do have the adapters I used in my install that allows bigger 5.25" speakers to be fitted.
    The standard head unit struggles to drive the replacement drivers I fitted probably due to their lower sensitivity rating (they need a bit of oomph to get them going) so I was looking for some cheap and sensitive replacement drivers and figured the more inches for the wife the better!
    So, are there any Audi's that use 5.25" speakers that would share the same characteristics and easy driveability of the original factory speakers that I could fit in place? Would they even need to be from an Audi or would any OEM paper drivers work?
    Factory speakers often turn up on ebay for a few quid so it seems a better option than cheap aftermarket speakers that may sound rubbish without an amp?
    Stu
    AK47UK's Avatar
    Sep 2013
    397
    Don't you just hate it when 4" doesn't satisfy her!
    you might find that other VAG stock speakers fit as I wouldn't be surprised if they shared the connection type but I doubt other manufacturers would (although comparing the connections on eBay photos could help with this). I'm not sure what the original power rating and impedance is, do you know? Might be worth playing it safe and putting a 4" set back in, let her deal with it
    AK47UK's Avatar
    Sep 2013
    397
    After a quick eBay search I can't seem to find any audi speakers of that size, perhaps they are all smaller although it would surprise me as my focus had 16cm in the front and 13cm in the rear.
  1. What model have I got?!...
    By Allen in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th October 2009, 14:03
  2. what model is this 20" oem audi wheel from?
    By shufti in forum A8/S8 forum
    Last Post: 9th March 2007, 09:31
  3. Audi OEM Bluetooth Kits available
    By imported_craigyjp in forum In-Car Entertainment
    Last Post: 6th March 2006, 09:38
  4. Audi OEM BT kit retrofitted into an A8/S8
    Last Post: 11th September 2005, 18:35
  5. FS: Audi OEM Bose Sub (including amp)
    By comdw in forum In-Car Entertainment
    Last Post: 13th June 2004, 11:14
