AH FabricationsEM Tuning
Results 1 to 10 of 10
    Oct 2013
    30
    How to tell if I do have Bose?
    Hi everyone, I'm new and have just bought a A3 8p 1.9 SE.
    It has a concert 2 headunit and the the door mesh grills say Bose, but is there a definite way to find out if I do have a car with a Bose system?
    Sep 2012
    LEEDS
    125
    If it says on the grill then it is wht it says on the box.
    Other wise take the speaker out and check on the back ?
    You should be able to tell from the sound and quality also
    genuine parts =genuine service
    Treat it right it'll keep you on the road .
    AK47UK's Avatar
    Sep 2013
    397
    From what I gather there is also a sticker in your spare wheel well and service manual which has a list of codes and you can decode these to see what options you have but if the grills say Bose then you should have Bose unless the previous owner removed the speakers or put the grills on.
    Oct 2013
    30
    I've taken a pic of the list of codes in the boot. Is there a decoder anyway to find what is what?
    The reason I ask all this is the sound doesn't sound fantastic.
    I've read on other forums that the head unit needs to be told it has a Bose unit attached. I do think the head unit has been changed since there is two manuals and two set of security codes in my log book. Both units have been the concert 2.
    Aug 2006
    NI
    785
    pull the boot trim back and look for a sub in the boot?
    arent the connectors on the back of the HU different for BOSE also?
    grilles mean nothing, could easily have been added.
    back to boost, oh how I missed thee....
    AK47UK's Avatar
    Sep 2013
    397
    Try this for decoding options:
    Audi Options Search
    im not sure if the HU needs telling or if this is done using a VCDS cable or not. The cable connecting to the HU wiount have been changed so the Bose pins should be connected. If you want to confirm this then I can compare your cars HU cable to mine if you take a pic of it so I can see the pins that are connected.
    Oct 2013
    30
    Okay he's a pic
    AK47UK's Avatar
    Sep 2013
    397
    Ahh, my headunit uses the quad lock so the pinouts are different, I'm sure someone here will be able to compare yours to theirs though. Sorry about that, I hadn't thought to ask what connection you had!
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes you have BOSE you can see 5 wires for the audio at this end of the connector. But as you have speaker grills with BOSE written on it was pretty certain you had it.
    Oct 2013
    30
    Just wanted to make sure. It's not the first time I've seen someone market something just because of the badge and have something completey different under the hood.
  1. How do I tell which engine I have to select correct temp sensor
    By Taff D in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2011, 19:48
  2. How to tell if you have a full Bose or only rear amped system
    By SteveTDCi in forum In-Car Entertainment
    Last Post: 27th March 2008, 18:26
  3. Bose Speakers - how to tell?
    By akz786 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2008, 12:04
  4. How many optional extras do I have?
    By Garth_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2005, 12:43
  5. How to tell if turbos need replacing in as S4?
    By imported_druggie in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2004, 18:22
