EM TuningMonster Motorsport
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    Aftermarket headunit
    Hi all, im looking to replace my concert stereo in my 2002 s3. Just wondered if my std fitment amp and sub will still work as im unsure which wiring harness to use. Will it be a plug and play with just a eg. Sony headunit, loom from sony to audi and then all existing speakers and amp and sub work?
    thanks in advance. Gez
    Dec 2006
    barnsley
    1,021
    yes you just need to buy the appropriate adaptor to make sure everything will work fine
    have a look at the autoleads catalogue it should be listed there what you need
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    gez
    S3 hunter
    Sep 2009
    Middlesex
    101
    Thanks mate
    Royston80's Avatar
    Oct 2013
    Leicester
    17
    Hi Gez,
    I have just replaced the girlfriends TT's Bose amplified sub HU with a Pioneer double Din system. Pretty much Stevie Wonder could do it. As mentioned, you can buy the wiring kits that are literally plug and play... If you have steering controls you can get these to work with limited functionality too (example... "Track" and "volume" buttons work but "source" does not). Connects 2 is a brand of wiring looms/adapters I have used with no issues.
    As far as the sub amplification goes the wiring feeds it all through correctly and you merely have to connect the red and white screened wires in the correct holes in the rear of the new HU.
    Also (and apologies if I offend any purists out there) IMHO the new unit sounds so, so much better than the Audi unit.
    Happy wiring!
  1. factory 6cd changer aftermarket headunit?
    By ian52 in forum In-Car Entertainment
    Last Post: 6th October 2008, 09:34
  2. Aftermarket Headunit Fitting
    By A3_Turbo in forum In-Car Entertainment
    Last Post: 31st July 2006, 18:58
  3. Aftermarket HeadUnit
    By yoda in forum In-Car Entertainment
    Last Post: 4th September 2005, 11:06
  4. Aftermarket Headunit for Audi. - Which one?
    By Luuc in forum In-Car Entertainment
    Last Post: 13th July 2004, 09:15
  5. Aftermarket headunit destroyed my bass!
    By Luuc in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2004, 22:52
