Sky InsuranceBadger5
Results 1 to 18 of 18
    Aug 2013
    115
    A3 8l 2003 rear amp too weak. Can I swap it with minimum rewiring. Ok leading 12v fee
    Want to improve sound in rear. Not enough bass as amp is week. Go alpine Ida 311 Hu powering front. Heard amping rear would improve things on a budget. Then at later date can get new sub box and sub. Was thinking of four channel amp but can I use existing wires for speakers and ignition wire etc. Then just lead a new 12v from battery.
    Not looking for mega power. Like a 150 watt amp just to balance front and rear out as Hu is 45 per channel.
    Other than that are the later models amps better. I know in 12 amp is bang olfuson. Could do a swap or maybe just with 8v A3
    Aug 2013
    115
    Anyone? Does anyone know anywhere that will fit a amp and sub for me then. Ilkeston area (notss/derby) not Halfords cause iI don't trust them
    Apr 2013
    49
    When I replaced the HU in my A4 B5 model I had the same problem - because the new HU provided the fronts with more power than the rear amp gave the rears the sound was out of balance.
    I found that if I fed the factory amp, not with the RCA rear output from the HU but if I fed it from the rear HU speaker output, after it had gone though a high to low convertor, it sounded much better.
    Basically this gave the amp a higher voltage input to work with, ie it gave it more to amplify.
    The balance was restored and it did sound more powerful albeit just because it went louder.
    Assuming your not feeding more than a genuine 50w from an amp then I would be happy to use the factory speaker wire and remote on lead but you should definitely improve the power supply cable and match it with a same sized earth for the amp.
    Stu.
    Aug 2013
    115
    I've just finished feeding speaker wire from rear output of hu straight to sub speaker. Giving 50w to sub instead of 20w. Sounds loads better. Rear speakers are still quiet but don't want to move sounds to rear to much.
    Dec 2006
    barnsley
    1,019
    just to check
    have you wired the rear speaker output of the headunit directly to the subwoofer speaker
    if so take it off immediatedly you will damage your headunit as the outputs are non bridgable
    what stu was saying it
    use the rear speaker outputs of the headunit and a speaker to line level convertor connected to the amplifier
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Aug 2013
    115
    Dam really. It sounded so good too. Didn't think they were bridged as sub is dual voice
    Aug 2013
    115
    I don't understand how that's bridge. Connected left output to one voice coil and right to other. Should I just disconnect one output. Didn't want to connect like stuffsaid bbecause that uses audi amp which is weak. This way get more power to sub
    Dec 2006
    barnsley
    1,019
    i assumed that the sub was single voice coil and that the outputs had been bridged to power the sub
    however it matters not
    you cannot run a subwoofer off the rear outputs of a headunit
    if you try and do so you will blow the headunit up and will then have no sound whatsoever
    if you have a dual voice coil sub you need an amplifier capable of driving it properly
    Aug 2013
    115
    It's only a 50w sub so why can't I use 45wpc hu. Audi thing is only 20w
    Dec 2006
    barnsley
    1,019
    dont believe the advertising
    under normal conditions all headunits can make an absoloubt maximum power limit of 18 watts rms
    this is because the chip which is used to amplifiy the signal cannot dissipate heat efficiently so is limited to the power it can put out
    the audi seperate amplifier will be far superior to a single chip which is in a headunit
    if you want to do it properly replace the amplifier with a proper one and drive the entire system off this
    Aug 2013
    115
    Oh Ok. Fair point about Hu amps. I know none of them would put at 50w like they claim but my main reason for Wiring this way was to I could give more power to sub than rear speakers. I didn't want to move soundstage to rear to increase bass.
    It now sounds better. Not great, I've had 300w amps just to power sub in boot and good speakers but I'm older now and ddon't h
    Aug 2013
    115
    Have 300quid spare to spend on amp box, amp and jl speaker
    Dec 2006
    barnsley
    1,019
    ebay is your friend !!!
    if you know what to look for you can spend relatively nothing and end up with a cracking system
    Aug 2013
    115
    Go on then what do I want? 6.5 inch sub and 4 way amp. Seen sub enclosure for 50.
    Aug 2013
    115
    I have all wires from old sub
    Apr 2013
    Barry S Wales
    60
    i'm currently trying to sell a vibe slick 12" sub and 600w ground zero amp if your interested,no use to me as i need boot space for pushchair
    Aug 2013
    115
    Barry a long way from me
    Dec 2006
    barnsley
    1,019
  1. A4 B6 rear amp wiring loom question.
    By 4NT in forum In-Car Entertainment
    Last Post: 18th March 2012, 00:14
  2. Power to rear amp in A3 8L
    By beanoir in forum In-Car Entertainment
    Last Post: 5th November 2011, 14:40
  3. Saloon rear amp
    By MarkWizard in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th February 2011, 21:59
  4. How to tell if you have a full Bose or only rear amped system
    By SteveTDCi in forum In-Car Entertainment
    Last Post: 27th March 2008, 18:26
