Sky InsuranceAH Fabrications
Results 1 to 9 of 9
    Jul 2013
    Birmingham, UK
    55
    Installation help??
    I'm very confused by the sheer amount of cables I'm staring at here. Are any of you guys good at installing stereos?
    Thanks in advance!
    Dec 2006
    barnsley
    1,016
    what would you like to know ?
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jul 2013
    Birmingham, UK
    55
    Quote Originally Posted by dualmono21 View Post
    Well where do I start. Firstly I'm slightly concerned all these cables aren't going to fit in?
    The connectors i can pretty much work out, although I'm sure there was one I couldn't fit in the adaptor. I'll take more photos next time, I'm just asking from memory now.
    The bullet tip connectors, is it as simple as connect the same colours?
    I've got a boosted aerial adaptor which has a blue cable with it, does that need to go somewhere? I noticed there's a blue wire on the cables without a tip, this related to it?
    Sorry if I'm being vague, as I say next time I'll take more photos. For some reason I thought this would be a fairly easy job, but it's really bamboozled me lol
    Thanks again for any help!
    Dec 2006
    barnsley
    1,016
    as regards the wiring id advise trying to tidy it up as much as possible and if possible wrap the wiring in either cloth tape or something similar
    with large amounts of wiring it can move and knock when you go over bumps in the road
    the yellow and red leads you have are live feeds one is ignition fed the other is permanent live
    im struggling to see the rest ... really could use some nice clear photos
    Jul 2013
    Birmingham, UK
    55
    Installation help??
    Ok here's a few pics of the wires I'm dealing with. Now I think on my last attempt I had the connectors in the right place, it's more a case of getting the bullet connectors in the right place and figuring out where the blue wire off the aerial booster goes.
    Here's some more pics, and quick tips would be great. I'm going to have another go and putti h it all together today.
    ImageUploadedByTapatalk1377340279.550532.jpgImageUploadedByTapatalk1377340287.973436.jpgImageUploadedByTapatalk1377340297.397328.jpg
    PS. sorry if the photos aren't great quality, they're the best tapatalk will let me upload?
    Jul 2013
    Birmingham, UK
    55
    I'm now getting power but no sound? Really confused!
    Jul 2013
    Birmingham, UK
    55
    The loose amp on cable from the HU, held to the amp on connector on the adaptor gets a signal. However it sounds like garbage, any idea where I'm going wrong? I've almost got it!
    Dec 2006
    barnsley
    1,016
    im sorry i simply cannot see enough detail in the pictures to tell you what should go where
    what colour cable are you using from the headunit to power the aerial adaptor ...
    Jul 2013
    Birmingham, UK
    55
    Thanks for the reply, I've actually now manage to get it all installed.
    What I struggled with was the blue wires to the amp. Once I figured a bit of soldering was needed, all became clear.
    Thanks for the replies!
  1. Dension ipod link installation help?
    By Keef in forum In-Car Entertainment
    Last Post: 23rd December 2006, 21:21
  2. cd changer install-help
    By scubadood in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th May 2005, 21:05
  3. Concert II install... help required pls....
    By m4tyj in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2005, 14:43
  4. cd changer install help in new A3
    By scubadood in forum In-Car Entertainment
    Last Post: 19th November 2004, 13:36
  5. CD Changer wiring installation - help
    By imported_bearboy in forum In-Car Entertainment
    Last Post: 7th September 2004, 17:07
