EM TuningVolks Autos
    Jul 2013
    83
    A4 B6 rear speakers low audio output
    recently bought a 2003 a4 b6 and the rear speakers have a much lower volume output have checked the fader on original HU and its ok when fully put to rear its very faint, from googling i think the amp drives the rear speakers would it be on its last legs?
    Dec 2006
    barnsley
    1,016
    if the front speakers are o.k
    then its either the headunit itself which is damaged , rear speakers or crossovers which are damaged
    or the pre amp on the rear channels of the amplifier , it wont be power supply or outputs on the the amplifier as it would detect the problem and not work at all
    try removing the lead into the amplifier and confirming your getting a signal in first (oscilloscope if you have one )
    then remove the door cards and check the rear speakers and crossovers ( put them on a tone generator if you have one )
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jul 2013
    83
    there was a time i would of had access to that test gear but not anymore, are the crossovers located in the actual speaker housings?, ill play around with it and try a trial and error process, is there any process to follow for elimination
    Dec 2006
    barnsley
    1,016
    yes the process of elimination follows the chain of audio
    so headunit first .... connection to amplifier (lead) second .... amplifier itself third ...crossovers fourth ... speakers last
    the crossovers themselves are only very very simple first order cap and coil affairs
    a diagram of the pinout connector would be handy at this point ... i could advise you which pins to check to see if you have audio output
    Jul 2013
    83
    Quote Originally Posted by dualmono21 View Post
    can i check the pinouts with a multimeter, i dont have a scope but a very good multimeter
    Dec 2006
    barnsley
    1,016
    yes but you will need a specific test disc to put through the system or you may get inaccuracies
    ideally you need a test disc with test tones on it .... preferably 1khz as this is the most sensitive part
    if you dont have a disc have a look round on the internet ... wink wink
  1. Aftermarket stereo, rear speakers and amp very low volume
    By Snaithy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th April 2014, 13:17
  2. Replies: 7
    Last Post: 23rd March 2008, 12:09
  3. Rear speakers not working
    By V1RDE in forum In-Car Entertainment
    Last Post: 1st November 2003, 16:47
  4. sony and very quite rear speakers
    By bredhurststeve in forum In-Car Entertainment
    Last Post: 9th October 2003, 21:58
  5. Anyone changed the rear speakers in a Bose TTR?
    By clived in forum In-Car Entertainment
    Last Post: 17th April 2003, 23:38
