Monster MotorsportEM Tuning
    Jun 2013
    6
    Is 5 door Bose kit/set up exactly the same as for 3 door?
    Hi, I recently bought my 2008 A3 Sportback 170 and am keen to upgrade from the standard speakers to the full Bose speakers/amp.
    If I buy a Bose set second hand from a 3 door A3, are the components fixings exactly the same to fit in my 5 door?
    Presumably I can reuse the existing speaker grills if necessary.
    Thanks!
    Marcus
    27,129
    Its a fair bit of work to do the Bose install tbh, wiring around the car, speaker changes, we can do all the work, but be under no illusions, it wont be cheap.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    AFAIK the SUB in a sportback is a different shape to the 3dr and also amp has to be fitted whereas your amp is currently built into the sub, so I would buy the right kit of parts. It's not impossible to do, but a big wiring job.
    mdre83's Avatar
    Aug 2007
    South East
    630
    I'm looking to remove the Bose system from my 56 plate SB sometime in the near future...out of interest does anyone know what kind of RMS the components and sub kick out?
    A3 8P2 2.0TDI S-Line 170 SB | Brilliant Red | Full Leather | BOSE | 6 Disc Changer | None Smoking Pack | Light Interior Pack (Converted to LEDs) | Rear Parking Sensors | S3 Air Vents | S3 Mirrors - Stolen!| S3 Pedals |
    Jun 2013
    6
    Thanks, that's helpful.
    Does anyone know of any guide to the wiring job? Even better if with visuals!
    Quote Originally Posted by s8craig View Post
    AFAIK the SUB in a sportback is a different shape to the 3dr and also an has to be fitted whereas your amp is currently built into the sub, so I would buy the right kit of parts. It's not impossible to do, but a big wiring job.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    You need to buy yourself a copy of Elsawin for all the diagrams and pin outs. It's not expensive from the bay
  1. Saloon doors the same as avant doors?
    By razputin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 14th February 2012, 21:53
  2. Cabriolet seats - exactly the same as 3 door seats?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th November 2011, 15:41
  3. Are 3 door, 5 door and cabrio front seats all the same?!?
    Last Post: 27th October 2011, 22:44
  4. are 5-door doors the same as 3-door ones?
    By kevandalice in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2010, 17:21
  5. On the look out for door trim (please help!)
    By S3 Johnny in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th March 2010, 19:55
Tags for this Thread
