Chris NottMonster Motorsport
Results 1 to 7 of 7
    Nov 2008
    44
    Stereo "pop/thump" when turned on
    I refitted the standard Concert yesterday but when I connected it up I still had the key in the ignition after turning it off. At the time there was a pop (which sounded like the remote pop you'd get with aftermarket amps and subs fitted).
    Now each time I turn the car/radio on, the pop can be heard.
    I have Bose in my car.
    Anyone any ideas? I left the radio out last night in the hope that it would have cleared over night, but its still doing it.
    Have I damaged something?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    What was in previously and what wiring changes were made?
    Nov 2008
    44
    I had a Pioneer unit in previously. No changes were made though, I just unplugged the quadlock adapter I had for the Pioneer and returned it to standard.
    Dec 2006
    barnsley
    924
    pioneer radios have issues with blown ground tracks on headunits which can cause damage to amplifiers im afraid
    the only other thing you can try is cleaning up the earthing points as grounding issues usually come from here
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Nov 2008
    44
    So even though all was ok when the Pioneer was installed, it could have damaged the amp and left it so it was only noticeable when the original unit was reinstalled?
    Clean the earthing points on the amp? How do I go about doing that?!
    You reckon the problem definitely lies with the amp then?
    Dec 2006
    barnsley
    924
    no i mean clean the earthing points on the car where the wiring contacts the body
    any differential between the differing earthing points on the car is likely to cause trouble so ideally find the earthing point closest to the headunit and the amplifier ...remove , clean and refit
    yes the pioneer unit is capable of damaging the amplifier without you being able to tell
    for some reason pioneer use a differant earthing method most manufacturers use a floating ground to avoid noise issues but pioneer
    use there own method
    Nov 2008
    44
    Ok, cheers.I have an RNS due this week that I'll install in the car first to try and determine if its the Concert or amp at fault.
  1. clonking noise when turning at slow speed
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2005, 09:47
  2. Spring noise when turning
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th August 2005, 14:09
  3. Noise when turning right
    By daverob in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st August 2005, 22:40
  4. creaking / clunking sound (offside front) when turning right ?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th April 2005, 22:38
  5. Occasional grinding when turning right..
    By Pegsta in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th January 2004, 22:28
