EM TuningChris Nott
Results 1 to 13 of 13
Thread: Order check
    Jul 2013
    Birmingham, UK
    44
    Order check
    Im looking to order all the parts to upgrade my stereo to an aftermarket unit, just wanted to check i have all/the right parts.
    I have an A4 2.0T S Line, with a Concert head unit and the Bose speaker system. What im looking to order is...
    Removal keys: PC5-93 Audi TT A3 A4 A6 Stereo Radio Release Removal Extraction Fitting Keys | eBay
    Bose adaptor: CT51-AU01 Bose Active System Adaptor
    Alpine UTE-72BT: Alpine UTE-72BT Media Receiver
    Facia adaptor: CT24AU03 Facia Plate for Audi A4 2000>
    Aerial booster: AUDI/VAG/VW /Seat /Skoda Amplified Aerial booster DIN | eBay
    Now i think that should be all i need. Let me know what you all think though, id like to get it all ordered asap. Thanks in advance!
    Dec 2006
    barnsley
    927
    with the engine youve listed im assuming its a b7
    the removal keys should be o.k but some stereos require 4 keys to remove them
    the bose adaptor yove listed in only one of a couple of differnat ones .... you need to find out what bose system the car is running
    is it fully amplified or rear and sub amplified ???
    the fascia adaptor youve listed is for a B5 AUDI SO PRE 2001 if your car is a b7 then it needs a later fascia adaptor
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jul 2013
    Birmingham, UK
    44
    Quote Originally Posted by dualmono21 View Post
    Its a b7 yeah. I can only see 2 slots on the stereo, so i think that will be fine.
    How can i check which system i have?
    Right, ill check on ebay for another facia adaptor
    Thanks for the reply!
    Dec 2006
    barnsley
    927
    my advice is nip into halfords or a small independant car audio shop
    they should be able to look and tell you which system you have
    26,762
    As its a single din, then its iso of course, 2 keys is fine & as its Bose its fully amp'd with feeds to amp & speakers out from the amp afaik.
    Jul 2013
    Birmingham, UK
    44
    Been searching the webs and the Bose system is always fully amplified. The non Bose system has an amp for the sub and rear speakers. In which case the adaptor i linked should be fine.
    Jul 2013
    Birmingham, UK
    44
    Does this look like the correct fascia adaptor?
    Audi A4 Fascia Facia Panel /Adapter /Plate FP-05-05 | eBay
    Dec 2006
    barnsley
    927
    yes thats the correct facia adaptor if you have the chorus headunit or single din concert
    Jul 2013
    Birmingham, UK
    44
    Sorted, thats the one i need then. One last thing, can i just clear up the deal with the aerial. I'll need a booster because the signal wont be strong enough for the aftermarket head unit to pick up right? Where is this adaptor installed?
    Thanks again for all the help!
    Dec 2006
    barnsley
    927
    most standard audi units will require you to add a booster , but some cars have actually got an amplified aerial fitted as standard
    i would suggest you try it first to see if it works and then if not simply order an aerial booster
    they can be fitted in between the back of the new headunit and the old wiring
    they should come with a short blue lead which will require splicing into the original wiring loom (sometimes this is white sometimes its blue)
    Jul 2013
    Birmingham, UK
    44
    Thanks for that!
    I've emailed car audio direct with this query, not sure if any of you guys would be able to help me with it.
    From what I know, the concert single din unit is iso rather than quadlock?
    http://www.connects2.co.uk/VehiclePr...=4&Model_ID=24
    According to this site, the 05 model should be quadlock. Or maybe I should just ignore this.
    I think I'll need the CT53-AU04??
    Any help will be great, I'm excited to get it all ordered.
    26,762
    05 non rns-e cars are iso, late 06 onwards are quadlock for all units.
    Jul 2013
    Birmingham, UK
    44
    So the CT53-AU04 would be the right one for me?
  1. Replies: 4
    Last Post: 14th May 2011, 15:22
  2. Ordering a new S3! Also, check out the deal I found...
    By magnus911 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th July 2008, 23:02
  3. Check out these made-up Audi's
    By MisterD in forum Other Brands & Models
    Last Post: 11th April 2003, 16:38
  4. Any suggestion on what to check first.
    By noodle in forum General Chat
    Last Post: 11th March 2003, 14:26
  5. forum orders......
    By SteveS3 in forum General Chat
    Last Post: 21st January 2003, 09:38
