JMB RetrofitsBadger5
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By NHN
Thread: Cd error service
    Avnt's Avatar
    Mar 2013
    228
    Angry Cd error service
    Ive checked the search to no definative answer. My concept head unit in my a4 on a 57plate, last week decided to make the ipod dock become a bit hit and miss. Has worked fine with my iphone 4&5 until last week. Then the cd player decided to stop working and wont eject the disc. Does it mean my HU is fubared?
    27,126
    I would try powering it all down & leave for 5 minutes & then back up again, also disconnect the ipod dock temp, to see if this is causing any issues down the line.
    Avnt likes this.
    Avnt's Avatar
    Mar 2013
    228
    Cheers nige. Failing that what are my options replacement wise? Another concept rnse or a symphony?
    27,126
    Well assume its the double din chrome knob unit?
    If its goosed then depends what you want out of the head unit, if you're ok as is, then swap for same unit I guess mate, upgrading to rns may give you degraded antenna reception unless you swapped some parts over at same time as rns.
    Avnt's Avatar
    Mar 2013
    228
    Its got the chrome detail on the nobs. Id happily keep it as is. Less likelt to attract a scrotes attention
    27,126
    I understand, best see if its just a little confused.
    Avnt's Avatar
    Mar 2013
    228
    I'll try the battery at the weekend and a lens cleaning disc as well cant hurt
  1. My day is getting worse!! Cd error service...?
    By DJ-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2013, 00:37
  2. audi service....any good?
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2003, 17:07
  3. Variable Interval vs Yearly Services
    By Nimo in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2003, 21:27
  4. Errors!
    By A4Steve in forum General Chat
    Last Post: 7th February 2003, 10:17
  5. Garage using your audi when its in for a service??
    By Chimera in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2003, 09:34
