Volks AutosChris Nott
    Jun 2013
    10
    seeking help with Q7 headrest video
    Hi, purchased a full spec 2013 Q7 S-line plus with B&O sound. It was B&O or Bose + Audi's rear entertainment and I went with the B&O. Meanwhile I have 3 kids that are more interested in Peppa and Mickey than booming B&O sound, so had to figure out an aftermarket rear entertainment system. Dealer came up with the Rosen AV7900 included with delivery of the vehicle, so I went for it. Bottom line on the Rosen system is that I can't stand it, given me nothing but trouble (started a thread on the AVForums site, you can read all about it there, won't bore you with detail here). So I will probably remove it and am looking for an alternative.
    I'm seriously thinking of just getting one of these iPad cradles and popping a few in the car and getting the kids BT headphones. But before I do that I wanted to see if there were other systems out there that could compete with the simplicity and video quality of the iPad - and do it in the headrest. Ideally the system would have the following specs:
    - integrate into the vehicle's video system (ie display the TV tuner and also output to the car's Aux input for the MMI screen)
    - iPod integration (perhaps 2, one for each screen) with the iPods out of the way somewhere
    - HD screen that has little/no video degradation from iPod video and displays correct video aspect
    Anyone on here have any recommendations? Thanks in advance.
    Dec 2006
    barnsley
    926
    there are not many screens that will compete with the ipad as regards screen quality im afraid
    the only one that will be near it is alpine and only certain models at that ... coupled to that you wishing to integrate in factory again this might not be that easy
    i can however reccomend a company in sheffield which have a very very good reputation for sorting things like this out
    the company is called source sounds and security 0114 2571550 the man to speak to is called paul ellis
    he has a very very extensive knowledge of being able to integrate aftermarket products such as you describe into factory systems
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    26,747
    Tbh mate, to save arguments with the kids, just make your life easier by fitting ipads, Q7 may have a wifi hotspot in the mmi, so that allows them to watch net based stuff easily if need be, bt headphones, job done & allot less money probably lol.
    I use a bmw headrest attachment which is bloody good tbh, they do an ipad attachment for it aswell, which is a fair bit of money for what it is, but tbh but its very good for holding it for the kids behind, only issue is you have 3 kids & unless you put 1 on the very back row & use a headrest of the second row for them, then that may create an issue if all 3 want to use there's at same time, but nly 2 are in place lol
    Need researching a bit more, ideally you need a system that allows them to watch what they want independently or did you want some control yourself so they don't watch anything dodgy?
  1. Q7 rear entertainment help/advice
    By paul_45 in forum Q3, Q5 & Q7 Forum
    Last Post: 16th June 2013, 21:49
  2. Help & Advice please - rear spring broken - 2000 A4 1.9tdi SE (115hp)
    By impster in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd December 2009, 19:11
  3. Please HELP!!! Advice NEEDED!!!
    By AVerma in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th July 2003, 16:34
  4. MOVED: A3t Rear Brakes....Help.....
    By richyboy in forum General Technical / How To
    Last Post: 12th June 2003, 14:43
  5. New rear badge - help required
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st February 2003, 21:42
