Chris NottVolks Autos
    Jul 2005
    croydon
    42
    Blade fuses - HELP
    Somewhere in my dim and distant past I recall seeing a blade fuse with an accessory tab on it.
    It seems to me that they are an easy way of tapping into a live supply and provided the accessory itself is fused correctly, safe.
    Trouble is that I cannot seem to buy one anywhere!!!
    Can anybody help?
    Jul 2005
    2,488
    Re: Blade fuses - HELP
    sounds a bit yee-haa to me. why not just run a feed from the fusebox? It probably easier to get to if the fuse blows too..
    Jul 2005
    croydon
    42
    Thanks for the comment.
    That said, I am not sure I understand!!
    Surely, it is "just a feed from the fuse box", just the front and not the back.
    As such, if the fuse blows it is just like changing any other fuse.
