Chris NottEM Tuning
Like Tree1Likes
  • 1 Post By s8craig
Thread: CD changer cable RNSE
    Jan 2013
    Middx
    16
    Hi all,
    I need the cable to link the RNSE Nav unit to CD changer, it's a MK1 unit with a glovebox mounted CD changer and my car is 2004 S4 cab. I saw one on e-bay but it's £30 is there an alternative ?
    27,126
    £30 isn't exactly expensive is it.
    Jan 2013
    Middx
    16
    No it's only expensive, if it's the wrong component and you have to abort an installation or there is a cheaper version available elsewhere
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Yes there are cheap versions, I made the mistake a few years back of buying a £15 cable from fleabay, installed it and the CD changer had squeeking and hissing when in use, basically the noise of the mechanism bled into the audio, so had to return with a better cable for around £30. So a cheap audio cable is sometimes a false economy.
    NHN likes this.
  1. CD Changer Cable
    By mattyboy199 in forum In-Car Entertainment
    Last Post: 25th July 2006, 23:00
  2. CD changer cable
    By Kevint in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th January 2006, 21:46
  3. Are there different models of CD changer cable?!
    By asifgillani in forum In-Car Entertainment
    Last Post: 18th February 2005, 17:23
  4. CD Changer Cable, and boot power
    By arthurfuxake in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th February 2005, 07:38
  5. Need help fitting a CD changer cable
    By Kevint in forum In-Car Entertainment
    Last Post: 16th July 2003, 10:50
