Chris NottVolks Autos
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By NHN
Thread: iPod dock
    May 2013
    26
    iPod dock
    Hi guys.
    I have an 8P S3 (2008) with an iPod dock.
    I use my iPhone 5 as my sat nav and I'd like to be able to charge it and listen to music (if possible).
    My windscreen mount is to the right hand side of the steering wheel.
    What would be the best way to extend and utilise the iPod dock from the glovebox?
    I was thinking of feeding a female 30 pin socket to male lightning cable to the driver's A pillar but I don't think such a cable exists and if it does, there's no guarantee that it will transfer audio.
    Any thoughts?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Is the Iphone 5 supported in the older Ipod docks, certainly not for charging.
    May 2013
    26
    You need a 30 pin to lightning adaptor.
    hendry10's Avatar
    Aug 2011
    norwich
    66
    As s8graig posted ..don't think it's possible ... My connection don't support io5 charging
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    The standard Ipod dock hasn't supported charging of any Ipod/Iphones for a long time. Not just Iphone 5.
    May 2013
    26
    Oh dear. Beyond useless then!
    Any recommendations as to fitting an A pillar based charging point then?
    I've been toying with the idea of insetting one of the little Belkin micro USB chargers and hardwiring it to a switched 12v source.
    The cigarette lighter socket in the centre console isn't viable as it's constantly on.
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Get a USB charger capable of at least 2 Amps to ensure charging.
    26,716
    A client recently tasked me while doing a large install, with fitting a switched power feed for his small camera warning system, so I wired down through the dashtop small vent which is directly above the fuse box, fitted a proper factory wired fuse point via spare slot out of 1-11, then bonded the charging unit onto the top of the vent which still allowed air out no problem, was invisible & perfectly working, when he removes he can replace the vent insert for next to nothing.
    You'd need a dremel to cut a hole upwards through the air channel, run wire through & seal the hole shut so as to maintain the air system as before & a repair wire for the fuse point, plus solder & heatshrink.
    This is to maintain a nice stealth & oem as best look as possible.
    gcon45 likes this.
    May 2013
    26
    That sounds ideal.
    Cheers!
    Avnt's Avatar
    Mar 2013
    209
    My dock charges my iphone in the glove box. I bought the charger adaptor off ebay for £6 and an extention cable. All works fine
    Jul 2013
    97
    Hi Avnt
    I could use this modification. Could you supply us with a link to the item or the search criteria you used when searching eBay for it please?
    Avnt's Avatar
    Mar 2013
    209
    17 Core 30 Pin Dock Extender Extension Data Cable Lead F Apple iPhone iPad iPod
    Im sure the adaptor i just searched iphone 12v-5v adaptor
  1. A3 Glovebox and audi ipod dock?
    By Rick Draper in forum In-Car Entertainment
    Last Post: 26th June 2012, 14:35
  2. ipod dock not workin with new nano Help!!
    By flyjakey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st April 2009, 08:04
  3. Ipod Dock + DAb + Input for CD/DVD Player
    By PaulAr in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 20th February 2009, 19:31
  4. Ipod docking station
    By sniperlover in forum General Chat
    Last Post: 22nd June 2008, 17:49
  5. Ipod dock to 3.5mm lead
    By Amchlolor in forum In-Car Entertainment
    Last Post: 21st March 2008, 10:17
