Chris NottEM Tuning
    amimmortal's Avatar
    Jul 2004
    Dunfermline
    226
    Help - disc stuck in cd drive!
    Hi all,
    I posted this in the A6 C7 forum, but I don't think it gets much traffic.
    I inserted a DVD into the CD drive (on hindsight probably not the best idea...) and now it won't eject. Nothing happening at all, just a "disc unreadable" message on the MMI screen (or something like that).
    Is there a force eject option? Somewhere to put a paper clip in to pop the disc out?
    Thanks in advance!
    A.
    Sep 2012
    61
    Hi Mate,
    Three ways to fix this first one might not work but did on my A3. Switch the car off (So Radio if off) Press and hold the Eject button along with pressing the power on button should reset the system,
    If this doesn't work, try to put another cd in (about 1cm ish so you can feel the other cd) and press eject as the might knock the DVD into place
    If neither of these work go hunting for some Tweezers and see if you can pull it out (Whilst's pressing the eject button)
  1. Help - disc stuck in cd drive!
    By amimmortal in forum A6/S6/Allroad forum (C7 Chassis)
    Last Post: 10th May 2013, 06:14
  2. RNS-D Sat Nav disc stuck!!! CD deffective on display?? HELP!!!
    By paulsaudi in forum Satellite Navigation
    Last Post: 3rd July 2011, 23:41
  3. help pls pc cd/dvd drive problem
    By fingermouse in forum General Chat
    Last Post: 11th July 2007, 13:54
  4. HELP - disc retaining screw
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2007, 00:20
  5. urgent help req pls.... oil on drive
    By fingermouse in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd September 2006, 12:09
