Volks AutosSky Insurance
Results 1 to 11 of 11
    Roswell's Avatar
    Jul 2005
    Glasgow, Scotland, UK
    311
    Best way to cut back of glovebox to fit Phatnoise?
    As subject really.
    Do I have to remove the whole glovebox or can I cut it from the front?
    Jun 2004
    Callander
    91
    Re: Best way to cut back of glovebox to fit Phatnoise?
    Glove Box should come out simply by removing 5 bolts - certainly did on my A4 which I've been playing with this afternoon.
    Would recommend removing it as it'll make it easier and safer to work on - you'll end up with a better job I reckon and probably let holes in your hands.
    Good luck
    scoTTy's Avatar
    Essex, UK
    1,958
    Came out easy on my TT and S4 so I don't see why the A3 should be different.
    previously LeeS3
    On the wirral...
    393
    you might want to mod the phatbox to fit the glove box. Ie remove it from its metal housing.
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    I would put it in the boot where nature intended!.. New glovebox is about 130 and there is not much room behind it on the A3.
    Personal choice though..
    previously LeeS3
    On the wirral...
    393
    Roswell's Avatar
    Jul 2005
    311
    [ QUOTE ]
    [/ QUOTE ]
    Yeah, I've taken the big aluminium looking bit off but where the glovebox slopes down at the back there isn't enough room to fit what's left of the Phatnoise in!!
    Is your Glovebox cut at the back Lees3?
    The911SC's Avatar
    Sep 2003
    1,032
    I dont think that is his install unless he drives a LHD?..
    imported_craigyjp
    The ones I have done are on the RH side of the GB, drop the GB and cut the back out the same size as the phatbox.
    The phatbox site slighty proud, but the door closes perfectly
    Craig
    Roswell's Avatar
    Jul 2005
    311
    Cool...thanks again craigyb!!
    gizze's Avatar
    Dec 2003
    Norfolk
    615
    [ QUOTE ]
    [/ QUOTE ]
    Is that a beige head unit?!! [img]/ubbthreads/images/graemlins/smile.gif[/img]
