Glove Box should come out simply by removing 5 bolts - certainly did on my A4 which I've been playing with this afternoon.
Would recommend removing it as it'll make it easier and safer to work on - you'll end up with a better job I reckon and probably let holes in your hands.
I would put it in the boot where nature intended!.. New glovebox is about £130 and there is not much room behind it on the A3.
Personal choice though..
[ QUOTE ]
you might want to mod the phatbox to fit the glove box. Ie remove it from its metal housing.
[/ QUOTE ]
Yeah, I've taken the big aluminium looking bit off but where the glovebox slopes down at the back there isn't enough room to fit what's left of the Phatnoise in!!
