EM TuningBadger5
Thread: what watt amp?
    Aug 2012
    telford
    211
    what watt amp?
    hi there im a bit new to sound systems. i have recently been given a pair of 6x9s and a 12" sub but no amp. do i just add the rms values together and then get an amp with a slightly lower rms wattage? any help would be appreciated
    Mar 2013
    90
    Rule of thumb don't mix 6x9s and a sub.
    if you're set on using both firstly you need to check the ohmage of the speakers and sub then check the rms. if you can find that out I can help you more in detail
    Aug 2012
    telford
    211
    Why should you not run them together?
    I only know the power and resistance of the 6x9s at the minute as I havent picked up the sub yet but as soon as I do I will get back to you. Thanks
    Mar 2013
    90
    If you fit the 6x9s on the rear shelf they will be running in the same air space the sub will in, in turn will make everything sound muffled
    Aug 2012
    telford
    211
    I was thinking of fittin the sub in the left cubby hole n then a 6x9 where the original little sub was but cut it into the side then the other 6x9 opposite in roughly the same position. Do you think thats not a gud idea then?
  1. Audi Concert what size amp in rear?!
    By localknoxville in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd April 2013, 22:41
  2. Replacing Bose amp in S3 8L what are my options
    By Westy in forum In-Car Entertainment
    Last Post: 30th November 2009, 13:08
  3. What amp to easily power 2x10" subs?
    By Toxik-Signal in forum In-Car Entertainment
    Last Post: 7th January 2009, 12:00
  4. what power stock A4 amp
    By fenian672000 in forum In-Car Entertainment
    Last Post: 4th December 2006, 20:05
  5. alpine amp bass boost does what?
    By dunk in forum In-Car Entertainment
    Last Post: 26th May 2006, 19:00
