AH FabricationsBadger5
    Stuart35205's Avatar
    Apr 2013
    Telford
    108
    Stereo background noise
    Today I have just fitted an after market kenwood to my 2000 a3 8L , the rear is run off the audi amp I believe aswell as the rear sub , it all works ok but with the sound down low there is a background whine from the rear ? Any ideas pls?
    Stuart
    2000 A3 1.8t sport AUM
    18 BBS LM , coilovers , strut brace , poly bushed f/end , S3 front discs , S3 rear lights , wrapped roof , face lift front lights , Forge tip , cone filter & heat shield , forge 007 DV , DV relocation kit , n249 bypass , n112 removal, SAI removal , scorpion back box , ECS shallow sump , ECS single mass clutch conversion.
    Jun 2003
    World of my own
    9,813
    You're probably using the hopeless speaker input adapter PC9-408, you need to use the RCA input adapter PC9-404
    This uses a straight connection between your pre-outs and the rear amp, the one you have uses a cheap hi-lo converter on your rear speaker connection which introduces hiss and alternator whine
    Alex Turner
    Mar 2013
    90
    Hate the 408 with a passion. Always found connects2 or incartec leads give you less hassle in most cases
    Apr 2013
    Telford
    108
    Cheers for the reply I believe I am using the pc9-408 which takes the green& purple wires & connects them to the red audi plug for the rear and its switched on with the remote output (blue wire from hu) so if I use the pc9-404 is this the one with phono leads in the kit?
    Jun 2003
    World of my own
    9,813
    Yes that's the one (as long as you have rear RCA's/phono's on the Kenwood)
    Alex Turner
    Apr 2013
    Telford
    108
    Yes cheers only a pair tho that should be enough looking at the pic of the wiring kit!
    cheers
    stuart
  1. Bluetooth interference/background noise
    By Jimmy mac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th January 2013, 18:25
  2. Stereo Help with AM and popping noise.
    By Stean in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2011, 21:32
  3. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
  4. Phat noise unit?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 18:33
  5. New Blunkpaunt Stereo's
    By Stormcatcher in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2003, 14:32
