AH FabricationsVolks Autos
    Feb 2013
    23
    aftermarket sterio/ariel connection help
    fitting an aftermarket sterio to my 2001 S3. everything is working fine but im confused on the ariel adaptor fitting? the kit i got came with this
    and i have 2 connections for my ariel in the car which are the cable hanging the lowest.
    how does this go together.
    many thanks
    Jun 2003
    World of my own
    9,813
    You have 2 aerials on the car, you just need to use the ISO one, the black one. Plug the black connector onto the end of the adapter and the other end into the new HU and then most important connect the blue flying lead to the power antenna connection on the new HU
    Alex Turner
    Feb 2013
    23
    power antenna on new hu. what colour wire is that then? would this just be a switch positive ? cheers
    Jun 2003
    World of my own
    9,813
    Blue with white stripe, labelled power antenna. Yes it is just a switched positive, so you can use remote on as well
    Alex Turner
  1. Ipod and sat-nav connection help.
    By qawsed in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th January 2010, 15:14
  2. aftermarket headunit 8l S3 help.....
    By wagon in forum In-Car Entertainment
    Last Post: 27th May 2009, 23:29
  3. ipod connection help
    By Matt in forum In-Car Entertainment
    Last Post: 15th May 2009, 17:24
  4. Concert II to Phatbox connection - help required
    By wingdiver in forum In-Car Entertainment
    Last Post: 20th April 2009, 15:57
