Monster MotorsportChris Nott
Thread: High pitch tone
    Feb 2013
    Edinburgh
    High pitch tone
    Iv had an ongoing problem with my car for the last few months now. Audi A3 8P with MMI/ RNSE and BOSE
    When the car is not running everything is spot on with the sound system
    However, when i start the engine i get an intermittent high pitch tone (Varies in loudness, length and interval between the noise) also it does not increase/ decrease dependant on RPM, the car can be idling and the noise is there or cruising down road.
    What i have checked:
    All ground connections within HU, Amp, battery, alternator etc. Battery condition is good and alternator works fine.
    The car had an aftermarket ipod lead fitted before i bought, i have disconnected this to check if noise was from here but still no fix. This was the only none standard component within car.
    Beginning to pull my hair out with it, unsure if the fault is with the amp or HU?(have checked for any usual water damage from rear window wash hose but all is ok)
    Just looking for any more ideas what to check or if anyone has had a similar problem?
    Thanks in advance
    Mikey
    Mar 2013
    90
    Earth track on the amp or HU would be my first guess ( althought normally gets worse with rpm ) , could also be a speaker shorting out try disconnecting 1 speaker at a time.
    Feb 2013
    Edinburgh
    Cheers Mart, will give that a go tomorrow. I had another wee go at it today....when i unplug the speaker out block at the back of the HU the noise get louder and constant.
    Ruled out the radio antenna amplifiers in the rear window being the cause. Disconnected these and the intermittent noise is still there. Does the sub have its own amp? If so would this be worth checking?
    Mar 2013
    90
    Should be all in one amp in the rear quarter
  1. High pitch tone from speakers
    By Mikeym87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th February 2013, 14:11
  2. high pitch mechanical noise when idle
    By A4NA18 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th November 2007, 20:11
  3. high pitch droaning noise from wheels
    By j4g3d in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2007, 19:22
  4. High pitched noise from rear speakers
    By Jay4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2007, 14:50
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
