Volks AutosEM Tuning
    Feb 2012
    Leeds, UK
    Question Concert II swap with RNS-E woe
    Hi,
    I'm not quite sure where this post belongs.
    To cut a long story short I'm swapping a Concert II with a friends RNS-E but have run in to a couple of problems.
    Current setup:
    My 2008 A3:
    Concert II
    No Bose
    No bluetooth/phone prep etc, Dension Gateway 100
    Friends 2011 A3
    RNS-E
    Bose
    Bluetooth/Ipod/Phone Prep
    The RNS-E fits in mine and powers up but I realise I'm going to need to grab a few things such as a GPS arial to get it working. What else would I need to do?
    I believe I also need to set a jumper for the Bose.
    The problem starts when we put the Concert II in the friends vehicle. Unit doesn't power on.
    Does anyone have any ideas?
    Any help is appreciated.
    Cheers,
    Liam
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    Concert II+ requires a safe wire alongside the main power wire. Check on the lid of the concert and you can see in D16 the extra power cable.
    You will also have issues with the antenna in the car your fitting the concert II+ into. You will need to join the two antenna connectors to the right hand side RNS-E antenna wire. So you need a Y splitter or it will stop picking up stations after a few minutes.
    Feb 2012
    Leeds, UK
    Thanks for the useful reply. That sounds simple enough.
    Quote Originally Posted by s8craig View Post
    Would there be any issues with me taking a feed from the same harness?
    s8craig's Avatar
    Jul 2005
    Manchester
    1,557
    No, it will work just fine.
  1. 2011 Black Edition with Concert - swapping for RNS-E
    By Ninja21 in forum Satellite Navigation
    Last Post: 20th February 2012, 09:00
  2. rns-d satnav swap with syphony 2 whats involed???
    By S3SYD in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2011, 00:05
  3. Replacing concert with RNS-E
    By danc in forum In-Car Entertainment
    Last Post: 15th July 2007, 22:20
  4. Concert-2 swap...
    By imported_mc119856 in forum In-Car Entertainment
    Last Post: 17th November 2005, 17:12
  5. Phatnoise with RNS-E Nav; Anyone got it working?
    By The911SC in forum In-Car Entertainment
    Last Post: 27th October 2005, 22:39
Tags for this Thread
