All Fitted and works yay!
Just one think. I have a Fault in on the car. Address 56: Radio 01044 - Control Module Incorrectly Coded. Is this easy to sort ?
Tuesday,23,April,2013,19:45:29:64396
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 77
VIN: WAUZZZ8P Mileage: 62510km/38841miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
Component: R4 2.0l PPD1.2 1247
Revision: --H42--- Serial number: AUX7Z0G3FN4131
Coding: 0000072
Shop #: WSC 06441 785 00200
VCID: 74EDCE001740A3B8354
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0023170
Shop #: WSC 06314 000 00000
VCID: 73EFCD1C124EA4802CE
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Component: KlimavollautomatH19 0360
Revision: 122426 Serial number: 8P0820043AC
Shop #: WSC 00000 000 00000
VCID: 6DDBDB64746A7270FAA
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006956116
Coding: 01884F07A014100000000000000000000008FE175C0100
Shop #: WSC 06314 000 08192
VCID: 408552D013784F1861C
Subsystem 1 - Part No: 8P2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00064784
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 H HW: 8P0 959 655 H
Component: Airbag 9.41 H13 4220
Revision: 91H13422 Serial number: 0037W0G1B1F0
Coding: 0071612
VCID: 479749CC36567820A06
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0004012
VCID: 418357D4187246106E2
Part No: XXXXXXXXXXX
Component: E0221 H07 0090
1 Fault Found:
01304 - Radio
004 - No Signal/Communication - Intermittent
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 F HW: 8P0 920 981 F
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 2243G004014643
Coding: 0004418
Shop #: WSC 00441 067 57207
VCID: 3B7F253C7A9E2CC034E
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 33001074020047
Coding: 3D0F03C207000101
VCID: 2F67016CBEE6C060886
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 62518 km
Time Indication: 0
Date: 2013.04.23
Time: 17:58:11
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0G3FN4131
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000560
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 356B33045CBAFAB0C2A
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 F
Component: KSG H08 0070
Coding: 1880202002186D088505488AC637
Shop #: WSC 00857 210 91343
VCID: 3F87512C6E8630E0186
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 HW: 8P3 035 382
Component: AB2 SUBWOOFERBOXH27 0160
Revision: 00005 Serial number: 30659635814998
VCID: F0E54210E3581F9851C
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000560
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 P HW: 8P0 035 186 P
Component: R Concert2+ H02 0270
Revision: 00H02000 Serial number: AUZ1Z3H8884904
Coding: 0610311
Shop #: WSC 00441 210 61830
1 Fault Found:
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Address 77: Telephone Labels: None
VCID: 55AB9384BCFADAB022A
No Faults Found
or DTCs not supported by controller
or a communication error occurred
