Badger5Monster Motorsport
Results 1 to 14 of 14
Thread: speaker whine
    Aug 2012
    146
    speaker whine
    Just fitted appradio to my bose a4. Getting a whine noise which changes tone when I accelerate. I believe its a ground issue if it does this but how can I check?
    Jun 2003
    World of my own
    9,813
    If you are using the hopeless PC9-408 adapter then that's the cause, it uses a cheap and nasty hi to lo converter on the speaker outputs which causes alternator whine. The PC9-410 adapter is the correct one to use
    Alex Turner
    Aug 2012
    146
    Im using ctsadoo3 with steering controls as it hooks up to the canbus so it works as the oem one does. dims with lights on and switches off only when key is pulled out.
    Jun 2003
    World of my own
    9,813
    CTSAD003.2 should be the right one, try earthing the chassis of the HU to the car chassis
    Alex Turner
    Aug 2012
    146
    What would be the difference with the .2?
    I will definitely try the chassis ground and report back.
    Jun 2003
    World of my own
    9,813
    That's the one on the connects2 web site
    Alex Turner
    Mar 2013
    90
    Had this before on a new a3 I couldn't sort it using that lead, so I used a incartech lead which worked perfect In Car Entertainment, Bluetooth & Multimedia fitting solutions and interfaces if they won't deal with you directly let me know. dunno where you've got the lead from? but if you end up sending it back dont let them fob you off with swapping the lead over in hope that its faulty because its not, make sure they change it for another brand
    or
    You can also try putting a earth on the outter of the RCA and re earthing the ground feeds on the Bose amp and head unit.
    the ctsar002 was the old version the ctsar002.2 , I'm pretty sure it's just a updated software on the little black box.
    Aug 2012
    146
    Just tried to ground the rca's and it made it alot worse. Ground the head unit directly, did nothing. If i touch the rca cables anywhere on the hu body i get the noise through the speakers. Dont know where to start with the bose? Going to get a couple loop isolators and se what they do. I had to modify the current harness so don really want to buy another one.
    Mar 2013
    90
    Yeah it does make it worse sometimes, you can get adjustable ground loops which sometimes help but don't expect the same sound quality. Trust me I tried new earth points on the amp and head unit, tried different stereos to different brands which no joy
    best bet use a incartech lead that will sort the problem, I know it's pain in the arse but if you're unsure of what you're looking for I wouldn't mess.
    9 times out of 10 the connects 2 leads are fine then you'll get that 1 car that really doesnt like connects 2 leads, I've got no explanation for it and I know connects 2 can't explain they will just tell you what's already been said on here sadly.
    Aug 2012
    146
    Will that lead work like my current one though. Or will I need to tap a switched power from the fuse box?
    Mar 2013
    90
    Pretty sure it's plug a nod play mate what year a4 is it?
    Aug 2012
    146
    53'
    Ordered some isolators as thats the cheapest option 1st.
    Mar 2013
    90
    Which ones did you get? If they are adjustable you maybe able to reduce it but you'll lose some sound. In my experience of using them they've not worked or made the problem worse most the time , maybe worth trying another unit if you have one knocking about? On the off chance that the pioneers earth track is faulty ( although I really can't see it being that )
    Mar 2013
    90
    I know you probably don't want to see this
    Incartecs leads
  1. Buzz / whine from speakers - aftermarket HU
    By s3audi52 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd October 2010, 12:48
  2. Whine/buzz from rear speakers
    By doublem_1 in forum In-Car Entertainment
    Last Post: 14th September 2010, 10:43
  3. Bose Speakers
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2008, 15:36
  4. Whine through speakers
    By Oranoco in forum In-Car Entertainment
    Last Post: 21st March 2008, 17:34
  5. whining coming from speakers
    By millsyd in forum In-Car Entertainment
    Last Post: 28th January 2007, 21:57
