Results 1 to 13 of 13
    Apr 2013
    13
    Help identifying correct lead for aftermarket head unit for my TT
    Hi guys joined recently I can't believe some of the knowledge you guys on hear have hope you can help
    I have a 2006 TT early Mk2 and I am replacing the Head unit with a Pioneer Appradio 2, bought it from Hallfrauds for a snip at £199.99 but they didn't have much of a clue as to the harness/ lead that connects the two, I searched the web and emailed various companies and was getting all sorts of different codes for the lead I needed mainly connect 2 manufacture, obviously they can't all be right so decided to buy local so if it was wrong I can take it back and they will have to sort it.
    Found a really helpful motorist shop near me he took my existing head unit out to look at the back of the Quadlock wasn't sure which one to order so rang his supplier ordered it in explained I would have to plug the front and rear speaker plugs into the back of my pioneer unit just plugged it all in just loosely to make sure it was the correct harness and it doesn't work the part number on the harness is Celsus ISO Lead AIS2265 hear is a picture of the back of my Quadlock and the Celsus lead
    Jun 2003
    World of my own
    9,813
    That is the correct adapter, you just haven't connected it up correctly
    The RCA's connect to the corresponding front and rear RCA's on the Pioneer
    The blue flying lead on the adapter connects to the power antenna or remote on feed from the Pioneer
    And lastly you need to provide a second switched live feed to the Pioneer as there is only a single permanent live on the Audi loom. I'm presuming that's the long red wire in the pic. This needs to connect back to the fusebox for an ignition on feed or you can just pair it with the permanent live already on the Audi loom but then you would need to turn the HU on/off manually. I seem to remember the AppRadio stupidly has no on/off option so you'd need to wire it back to the fusebox.
    Alex Turner
    Apr 2013
    13
    Quote Originally Posted by AndyMac View Post
    Hi Andy
    thats a relief it's the conect adapter, I know I have to connect the long red wire to a live, I was hopping to connect it via a relay under the steering column as you posted on hear, I found it whilst doing a search before I asked my question, is this possable to do with the Appradio2?
    When I say I conected it up and it did not power up the long red wire I connected it to the blue flying wire for the anenna I kind assumed that would give me live just to see if it powered up to make sure it was the right adapter, when it didn't work I looked at my oringernal quadlock and there are only six pins in the block but the adapter has only three and the bottom right pin on the adapter is black so I am assuming ground but the corosponding pin on the cars quadlock has a fatish brown wire which gave me some dout is this still right, and finally the orange wire which I need to conect to dim the backlights where would be easiest for to to splice in
    Jun 2003
    World of my own
    9,813
    Brown is earth in an Audi, so that is correct.
    If the HU isn't getting both 12v feeds then it can't turn on so it can't give you 12v on the power antenna feed, which means it can't turn on - catch 22. Just connect it to an ignition live and it'll work
    Alex Turner
    Apr 2013
    13
    Thanks Andy once again lol
    brown is earth? Pesky Germans, I can see you point about the blue flying wire not beeing live without both live feeds nice one mate cheers Paul
    Apr 2013
    13
    Bought my relay for key operation on head unit just want clarification on what's what,
    Pin No30 self exspianirty feed from spare 12v supply via inline fuse
    Pin No85 earth does this need to come from the headunit or is anywhere on chassis OK?
    Pin No87 where it say auxiliary lamps presumably to the headunit?
    Pin No 86 where it says supply from ignition or lighting switch I assume is to where you splice into the thin red wire below the steering Column
    Mar 2013
    86
    Out of interest why are you using a really?
    Apr 2013
    13
    Because the thin red wire under the steering column that picks up the key operation apparently has low voltage so that when you insert your key it opens the relay allowing the 12v to go to the Headunit to power it up and removal of the key will work the opposite and kill the power that's how I think it works from searching various threads on hear, but I am guessing this otherwise I wouldn't be asking my questions lol
    Mar 2013
    86
    Ok fair enough I guess lol
    Jun 2003
    World of my own
    9,813
    Yes 86 is the trigger - skinny red wire under steering column
    87 goes to the HU red wire (switched live)
    85 is the earth - can be any earth you like
    You need a relay as the feed from the igntion switch is very low current, like a remote on, and would not be man enough to power the HU
    Alex Turner
    Mar 2013
    86
    I know what the relay does I was more interest to why it was being used in this case, most people just want it to turn off with the key and the car has a load of ign feeds that you can tap off without using a relay, unless my multimeter has been telling me lies for god knows how many years.
    Jun 2003
    World of my own
    9,813
    No one wants it turn off with the key, they want it to turn off when you pull the keys out, just like the stock HU. To do this you have to use the skinny feed off the ignition switch as there aren't any on the fusebox that stay live until the keys are out.
    Alex Turner
    Mar 2013
    86
    Not saying its not a good idea however in all the time I've spent in the audio trade I can remember only one person requesting it turned off when the key was pulled out and that was a in a vw t5. Really I don't want to get into a argument about it I respect you've gone and found a way yourself .
  1. A4 Cabriolet - Aftermarket Head Unit Help
    By N16MKE in forum In-Car Entertainment
    Last Post: 14th January 2013, 20:10
  2. Replies: 10
    Last Post: 8th October 2012, 16:24
  3. Aftermarket head unit help
    By S3 Skot in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th September 2012, 04:31
  4. A3 8L Aftermarket head unit install help required
    By robsta3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2012, 12:48
  5. Help with radio code for Chorus Head unit
    By mateus in forum In-Car Entertainment
    Last Post: 9th October 2007, 13:22
