Sky InsuranceChris Nott
    Mar 2013
    Help needed re new Hu install for W reg June 2000 A3 8L
    Having decided to bite the bullet and replace the oem Concert I and Cd changer with a nice shiny brand new Kenwood KDC-BT92SD; I'm a little confused as to exactly what I need in the way of harness adaptors and facia plate etc. It's the standard rear amplified set up and I have no idea what would be needed to install the new HU and how, if possible to get it powered so that it works with the ignition key inserted like the oem setup. Any help and advice gratefully accepted.
    Charlie
    Jun 2003
    World of my own
    9,813
    You'll need a PC9-404 RCA input adapter, powered antenna amp adapter an fascia plate
    Autoleads PC9-404 Audi Harness Adaptor (RCA, non-BOSE) 7.99 including VAT. PC9404. Buy discounted car audio online at In-Car Express
    CT27AA05 Aerial/Antenna VAG Active ISO Adaptor
    CT24AU07 Facia Plate for Audi A3 2000>
    You may have an ignition on feed at the HU, if not then you'd need to wire one in from the fusebox, use fuse "Radio S-Kont" this will give you on/off with the keys and it'll stay live until you pull the keys out
    Alex Turner
  1. Help, need a new pump
    By Cruz in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th December 2009, 16:52
  2. I need a new steering wheel for my 2001 S3...need advise please!
    By Dennis Moeller in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th December 2008, 16:01
  3. HELP. Need to find a part for my car.
    By G4JSG in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th October 2008, 21:08
  4. Help needed - rear R32 19mm ARB for S3/TT
    By Rai in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2004, 07:20
  5. Help! Need a new coilpack!
    By SteveS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd January 2003, 22:29
