Volks AutosMonster Motorsport
    TED7's Avatar
    Couldn't Find Reverse Gear
    Mar 2013
    Derbyshire
    37
    Wiring in a removable sub.
    Hello. I have a sub with amp screwed to it in my old car, which I'm thinking of transferring to my B5 avant but would like it to be removable because the dog lives in the back sometimes. Does anyone have any suggestions on how to go about it? I'm thinking of wiring the two power leads up with a 2-pole speakon joint and the remaining phono and remote lead with a 3-pole XLR. All routed through the cd changer hatch to the front of the car.
    Or do I make the amp permanent somewhere and just run a speakon lead to the boot for the sub. Any thoughts?
    _G_
    _G_'s Avatar
    Jul 2011
    869
    Fast plug for the amp wiring: Vibe FastPlug
    You could hide the fast plug under the boot lining or try plush fit it to the boot side wall or have the amp exposed to said dog.
    Sub removal is often easy if you have a sub box.
    Or... my uncles avant... mounted the amp under the driver seat... and ran two speaker wires to the boot to a connection post - and then connected to that whenever needed.
    I'd say consider a false floor
    TED7's Avatar
    Mar 2013
    Derbyshire
    37
    Thanks G, amp under the seat / socket in the boot sounds like the best way.
  1. checking / removing sub in Avant '98
    By TeKnodriver in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th July 2011, 22:14
  2. Removing Sub
    By dandowftm in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2009, 22:19
  3. Wiring problem with aftermarket sub/amp/HU
    By jamies in forum In-Car Entertainment
    Last Post: 21st February 2007, 11:30
  4. Removing Bose Sub (1999 A3) & Keeping Rear Speakers?
    By SyA3Turbo in forum In-Car Entertainment
    Last Post: 8th March 2006, 19:05
  5. Boot trim/sub removal
    By AndyMac in forum In-Car Entertainment
    Last Post: 8th February 2006, 12:55
